Which Brake Fluid?
Which Brake Fluid?
Stock 75 Corvette
I already ordered it and I now have the parts, this weekend I'm about to replace the Master Cylinder and upgrade the old rubber brake lines to new stainless steel brake lines the has stock disc brakes and I plan to flush the current fluid.
Which Dot brake Fluid should I add?
How much will I need?
thanks,
Ralph
thanks,
Ralph
Brake Fluid
I agree that Dot 3 is what you should use: I asked this same question on this forum many years ago and was surprised that many of the members here replied and told me to buy the Dot 3 at a FORD dealership as it was the best for our Corvettes. It is Ford Dot 3 and I have used it for years.
I did so when I restored my 68 and the Ford parts guy was shocked when I told him who recommended the fluid.
Kurt
Kurt
I just finished a complete replacement of calipers, lines and master cylinder and used Dot 4. It has a higher boiling point than Dot 3 but is not silicone. It is supposed to be compatible with Dot 3.
It has a higher boiling point but is not necessary for normal driving. But no harm done to use it. I have.
the cover says that because perhaps that was the highest available in 76. Not only is the boiling point higher as the number goes up but more importantly the hygrosopic properties increase, resistance to water absorption. So DOT 4 or DOT 5.1 would be an improvement
http://en.wikipedia.org/wiki/DOT_5.1
That's true. The previous posting referenced DOT 5.1 which is glycol based, not silicone. DOT 5.1 appears to have the same temperature properties as DOT 5.
