Pulling motor
Pulling motor
Ok so I am trying to pull the 383 stroker that is in my 74 corvette. I have the cherry picker and the engine stand. I have been trying to find a place that has the steps and equipment needed to complete this. Also I am unsure of where the anchor points are on the engine to do this are.
I used bolts in the ends of the heads to attach the chains to lift mine. If you are pulling transmission too you will want at leveler. As far as steps you can use a Chilton book for basic process. I spent a little time looking at what had to come loose or off and just started working my through it. Bag and label the bolts, id wires and other items you disconnect. Taking pictures or things before disassembly comes in handy. The key to taking it apart is removing bolts. The secret to putting it back together is knowing where those bolts are and where they go.
any chiltons manual for a chevy RWD has the procedure. there should be lift eye straps on the motor from the factory, kitty-corner from each other for lifting. you can also just use strong bolts, or they make a plate you screw onto the intake in place of the carb.
high level overview;
take off hood, remove radiator, fan, etc.
remove accessories, starter, alt, etc.
remove hoses, wiring, trans lines, etc.
unbolt flywheel from trans
unbolt trans from engine
jack under trans to hold it
unbolt motor mounts, not from block, just the long bolt connecing the two. 5/8 I think but don't quote me on that...
lift and pull...
hints:
long 3' extention helps to get trans bolts to block from behind underheath if you can't reach from top with a wrench. 9/16 and swivel.
tq cvtr bolts are super duper tight, 11/16 I believe.
flywheel turner helps.
3pc set of craftsman prybars helps to pry away and maneuver the motor from the trans.
don't jack the trans much, just enough to hold it.
lift and pull...
hints:
lift and pull...
hints:
lift and pull...
hints:
Later,
Lee
lift and pull...
hints:
lift and pull...
hints:
lots of guys leave the lift eyes off. you can go grab some from a junkyard, or just bolt the chain right to the corners of the heads with strong bolts. the lifting plate is aftermarket and bolts to the carb mount.
here is an example on ebay, but any parts shop carries them
http://www.ebay.com/itm/like/331540283537?lpid=82&chn=ps
I forgot the step to remove exhaust/manifolds, but you'd figure that out anyway...
