My "somewhat of a" restoration / mod
This is project is coming along great!
Just an observation, and you probably already thought about it, but the top rear of the front fenders where they transition into the door look like they need a little help so the line will flow better.
Keep up the good work.
They do. I've been fighting with hanging the doors just right. The car had horrible gaps when I got it. I think the passenger side had over a 1/4 inch gap at the top. I actually ground the depth of the glass down on the top of the fender and laid in strips do extend it out and close the gaps in. I actually left very tight gaps on the passenger side and will massage it right. I gotten up in the middle of the night to go look at it and think about it... It bothers me that much. I think it needs one of the upper door hinge shims taken out now that the gaps are tighter and pull the door in more. Going to wait for paint when the doors come back off to get er done.
MISTERZ06 (04-21-2017)
C3 of Year Winner (appearance mods) 2019
Man this project took on a life of its own!
Looking really good and am looking forward to seeing the car when it's finished.
Oh wait. They are never finished.
sirleo (07-29-2022)
Headlight adjustment repair kit was supposed to be in today but no luck. Managed to get the front pretty much back together though. Pop up covers were a real PITA to get adjusted. Found a good use for some old ARP header bolts. Thought about going old school vintage racer look with bumper delete. I think the header bolts would be a pretty cool old school look.
Man RC...and I thought I had a project...looks great!!!! In doing mine I can appreciate the amount of work you are pouring into this. Few questions....the double fan on the rad....did you do this due to an overheating problem and did it solve the problem? Reason I ask is mine overheats a bit when I run at high speeds. Also, what type of manual tranny did you install? Again, really a jaw dropping piece of work...good job!!!!
Only had to put new clutch and flywheel since running a small block. Was going to delete bumpers and go the vintage racer look (shed a few more pounds) but didn't want to buy the Daytona lights so might look at what's available in glass bumper wise. The place I got the flared fenders from has a front fiberglass bumper I know of so far. Post some pics of yours as I'm always looking for inspiration.
#33
RC...look at my thread " 76 project in pics" and you will see mine. I also added the wide meats on the back but was afraid I was not skilled enough to glass in a quarter panel so I decided to go with the prefab flares....still they were an ill fit at best and needed a lot of massaging to get right. It is my first try at bodywork and paint. I opted for the 295-15.5-15s on the back. I have the fiberglass bumper in the front but it is like a skin....mostly steel underneath so the amount of weight savings may not be worth the loss of a nice chrome bumper...still I understand you wanting to shed every pound you can
#34
I stripped the entire body with razor blades. I don't even want to guess how many hours I have in strippin more less hanging fenders and glassing in the bonding seams (easiest part of all) I have a whole new respect for paint and body men. I would much rathere mechanical work. Can't wait to get Into the suspension. Having a blast with a sand blasting cabinet bringin these 40 year old Parts back to life.
#35
I moved to be closer to work, so the car was stored for about 6 months. The rear had some damage in the glass, so more fiberglass work was in order. Probably ruffle some feathers, but I glassed in the front fender gills. Nothing original on the car anyway. Finally got color on this past weekend also. Duplicolor performance red. Just need to compound, polish and wax.
#36
Nam Labrat
Received 4,178 Likes
It's looking good!
#37
Dementer sole survivor
Received 6,291 Likes
2016 C3 of Year Finalist
Great job!
#40
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Looks good! Where did you get those '68-'69 side gills? I want to covert my '71 like that too.
