77 AC Condensor Removal
77 AC Receiver/Dryer Removal
How hard is it to remove and replace the AC receiver/dryer on a 77? It appears that it would be extremely difficult due to the fact that it is tucked in behind the coolant reservoir and in a very hard to reach location. Is it bolted in place or is it just held in place by the coolant lines that are attached?
On my non VIR '77 it is strapped to a bracket with a metal band held with a small bolt. It is best reached from the bottom by removing the splash shield behind the tire. I used a cut off 10" Crescent wrench to tighten the fitting that is in the fender well area. I was able to find a one piece that made the alignment easier. Start the fittings with the strap off then secure with the strap and then final tightening. mike...
There are four bolts. Two vertical at the fender flange and two horizontal behind the rocker cover. I forgot to mention the rocker cover must come off to access those two bolts. Use a little refrigerant oil on the new o-rings, the threads on the fittings and the pipe where the female fittings rotate. This greatly reduces the tendency of the components trying to twist and prevents damage to the o-rings. mike...
And ... Don't pop open the the dryer until you are ready to install and then immediately pull a vacuum on the system, otherwise the dryer will be sucking the moisture out of the ambient air or in the system.
Frank
Frank
