Question for.......... DUB?
Trying to put floor pans in when the body is on a fixture that will secure the #2 and #3 body mount areas of the 'birdcage'. It is possible that the floor pan can drop down a bit further and 'possibly' cause an issue when you set the body back on. UNLESS good measurements are taken. But I prefer to not take the chance.
I am sure that you are more than likely welding these in place instead of using 'metal to metal' body adhesive like is used on current cars of today. You are more than likely lapping the steel...and if you do... I advise you in prepping the steel that is BETWEEN the two pieces with an aerosol 'Weld-Thru Coating'. SEM and 3M sells some good stuff .
Then I use the SEM seam sealer on the seam on the underside and make sure it is sealed up so NO WATER can get in your seam. OBVIOUSLY the metal in this area needs to be prepped accordingly so the seam sealer will work and adhere correctly. When I get done...you REALLY have to hunt for the seam.
DUB
