Finally have money for build
Its been a while, but ive finally got some decent money to do a build, its took an eternity. Finally, its about time to start my projects one at a time. Heres where im at im about to put into the vette what i could buy a new car for in the end a little bit at a time, so im debating a new daily driver and vette just for fun. Or turn my vette into the biggest beast on the road.
While vette will be out of commision i still have Cadillac. So heres plan for the vette.
First new (or used but nice condition) engine, tranny, flywheel, rear end all of it,
I think i want to custom build a 383. I know people around my town that build race cars , one of them has been a good friend for my whole life, he build his race cars our of chevy parts so he has alot he can give me deals on and help me with the project to get done both far faster than i could alone , and for much less than a shop would do for me.
After that, and new heads, cam, pistons, and so fourth, then my exhaust will be my current exhaust plus two side pipes i have on switch to turn on all three during car shows and drag strip but only have rear exhaust on in town. we then move to the enterior, rear window louver, already installed led running lights, tint windows, have off road tires (I know rough ride but they look nice plus I have other tires i use at drag strip) last if anyone has ever seen the mustang on fast and loud you will understand, i want to put lights on top of car on the top that remains when the ttops come off.
Last we move to interior, this will be super pricy too. Recaro seats, custom dash and consol my buddies will build me, for a great price (still expensive) then new gauges , keeping my current bluetooth radio and speaker set up I installed. I know half of you will hate this half will love it. Its my car this what i want. Let me here your feed back and tips anyway, I think if i really watched it i could keep build under 20 but knowing things never work out hoping to stay under 30. Build would be more expensive if I didnt have connections for almost every part if build. I probably will do this over time instead of all at once.
I think if I was going to start a project C3 from scratch, I would consider dropping in an LS1 and 6 speed out of a late Camaro. Prices have really come down, and in the long run, would be cheaper and more reliable than building a stroker small block. I would go as far as installing a plug and play intake, so I could run a carburetor. Just a thought.
Ive thought long and hard about both, the problem with the camaro engine is you actually have to have more skill and knowhow to install it than i do. However if i did, I would probably go a fuel injection route instead of a carb. Altho that would make a couple thousand dollar more expensive project. My main concern, with the right parts, could I make the ls1 as big and bad as a 383 small block??
I would take my budget and do a lot of research before deciding what to do.
Building a 383 might be more expensive compared to a new crate 383. You may be able to build cheaper, but it will take time and probably good prices on used parts.
The LS definitely would take more mechanical skill, but could also be done much more reasonably with used parts, but again time to gather all the parts. It will take a lot more parts to make everything work than the 383 will. With the right parts, you could build a 6.0 truck engine that would more than hold its own with the 383.
If you rely on paying someone to do most of the work, that will be a large part of the budget. General things, like engine and trans work, can be done by most any decent mechanic. If you get into rear end and suspension work, you may need a C3 experienced shop. Whomever you choose, make sure they are good, and get clear expectations set up before you start.
Good Luck
Good Luck
Your post is very detailed! thank you everyone for all the imput do far, now im rethinking what to drop in the car. I want max bang cheap as i can go. If the ls ends up being the way I go ill end up probably having to let somone else do the computer part of the install for sure. Would it be cheaper for a new 383 crate or for a built up ls to match or pass. Please give me imput while i research. In mean time I may start other parts of long build such as recaro seats and window louvers. Also I hate the two mainstream louvers I find every once in a while i see a cool rare one. Anyone have an idea where I can get my hands on one???
Well, I had a shop take my 72's original 350 block and bore and stroke it, installed a forged rotating assy, retrofit comp cams roller cam. New aluminum heads. From new oil pan to new intake, $5k.
I happen to have a 2014 SS Camaro with the 6 spd manual trans. 426 hp. Just an FYI, Many people don't know this but the auto trans cars also have a 6.2 engine, they have a lower profile cam and cylinder deactivation, only 400 hp.
Anyhow, had I to do it over again, I may have just gone with the new LS engine. The rebuilt 383 looks period correct, which is why I did it. The power is very good, supposedly 435 hp. Sounds gnarly as all hell with the cam I have in it. So why would I go with an LS 3?
It is a very smooth and efficient engine and really runs strong. It takes very little work to make these engines into monsters.
big block
I was looking on craigslist and complete running and driving 1998-2002 z28 's are going for $4k to $6k. Even with 100k + miles, these motors are solid and bulletproof. You could take out the drivetrain and anything else you could use, and part out the rest and get most of your money back. And you'd be getting a modern, aluminum block, roller cam, fuel injected engine and a sweet t56 six speed with a .50 overdrive 6th. Put some C5 plastic covers on it and you'll impress anyone when you open the hood.
Spent money
Thank you everyone. I finally decided to temporarily invest money elsewhere instead of the vette. Ill keep it and someday put money into it. But for now I bought a new camaro
Bought about two months ago. Thanks everyone for everything. Ill still post vette questions but not as regularly now. Got some cool pics of the cars together
