Wet exhaust wraps - run engine to dry?
I'm about to install a new dual exhaust with headers. Some hot rod guys at work recommend that I soak the wrap before I install it. Yes... I was planning on doing that. But one guy suggested that after the wrap has been installed, to ensure that the wrap conforms tightly around the pipes, I should run the engine afterwards to dry out the exhaust and cause it to shrink. Is this valid?
After a day or two the wrap dries on it self.
Also if you use the high temperature paint on the wrap, as I do, it should be heated three times, each time at a higher temperature.
I use the wrap on the pipes, not on the headers. My headers are ceramic coated.
