What motor came with my 69 Vette
Hi all from OZ, my 18 year old son has just purchased his dream car which is a left hand drive red C3 1969 coupe.
It was originally imported from South Africa to New Zealand and then from NZ to Australia the VIN is 194379S702377 I have yet to confirm that the chassis has the matching number because it has been covered in dodgy sound dead spray. I have found it has a 305ci engine from a 1978 vehicle going by the engine number. V1230CTH 70S401051.
Is there any way I can find what the original engine was?
I still have to see if the 4 speed manual is original and it seems to have pretty short rear gears.
Any help would be very much appreciated.
Cheers.
rossi.
Cheers.
rossi.
Without having the build sheet...I do not think that there is a data base that would have the specific information of your car exclusively. Unless something new has been added to the internet.
DUB
DUB
Received 2,878 Likes
Hi Rossi,
Dub's right, the build sheet that was originally on the top of the gas tank had the information you're looking for. Might it still be there?
There are other clues such as radiator and tach redline that can be hints, but the tank sheet holds the truth.
Regards,
Alan
This is the tank sheet for a base motor car.
Regards,
Alan
Cheers.
rossi.
Hi Rossi,
Regards,
Alan
Regards,
Alan
just never know if it's still there.
I'm going to clean all the paint off the trim plate so I can read it and it looks like the interior was red but someone painted it black.
Cheers.
rossi.
What's the casting number on the block? According to my restoration book, from the numbers you have it appears that you have a 70 350. The partial VIN and the engine stamp ending in CTH indicates a 1970 350 with a 4 speed manual.
Let's hope its not a 305 cubic inch engine..these were very low HP engines sold in the early 1980's for Corvettes. For a 1970 it should be a 350 cubic engine...keep in mind that in the early 1970's, these engines were known as "small blocks," aka mouse motors...in the 1970's the "big blocks" were known as rat motors. In today's world, it's unusual to refer to a 350 cubic inch engine as a "small" engine!!!!! Anyhow, the small block Chevy engine..in all of its dynastic variations, is one of the most phenomenal engines sold for passenger and racing car useage.
I found on the trim tag that paint is either 974 or 976 hard to read and trim is 407.
Cheers.
rossi.
This is what I found in the casting number search.
Even though the engine number having CTH on the end, which is also a 305 and a big block
3970010 Engine Blocks Small Block V8 1969 302, 4 bolt, Camaro Z28
3970010 Engine Blocks Small Block V8 1969-1980 350, 2 bolt or 4 bolt
The engine number V1230 CTH means it was a Flint made December 30.
The preceding number is a bit confusing being that it starts with a 7. is 70S4010S1
The casting date code is 0917.
Cheers.
rossi.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,324 Likes
I assume you know this, but if the red car in the picture is actually a 1969 it has been heavily modified. The rear valance has been molded into a 1 piece and the exhaust re-routed under the car. It appears the entire nose (doors forward) is off a later year car and a chin front spolier molded in? Mirrors added, aftermarket wheels. Rocker panels are '70 and later. Can't see the hood well enough to guess the year; the wiper door assembly looks like it's removed. Spare tire tub is gone.
The interior appears to have a '77 - later shifter console with some sort of shift lever I dont recognize. Actually, the entire dash seems to be 77-82. The seats are 79-82. Not sure whats up with the steering wheel. The door panels look like '69.
There's very little 1969 left on the car.
None of this is a criticism, I'm just not sure how much of this you know as you are inquiring about the originality of the engine and transmission numbers.
Cheers.
rossi.
Based on the VIN number and suffix code, I'd say that the engine is a 1970 Corvette 350/350. Besides being used as a 78 305 suffix code, CTH is also believed to have been used to indicate a 350/350 on some 70 Corvettes.
70 Corvette VIN derivatives started with "70", to indicate the year. The "S" is the St. Louis Corvette assembly plant, the "4" was a GM control number used in 70, and the 010S1 is the car's production number, though I suspect the "S" is actually either a "5" or an "8".
As Vettebuyer said, many of the parts on that car, are not 69, or original to it.
The dash is from a 78-82 Corvette, as is the steering column, console and seats. It appears that the speedo might be an 85 mph unit, which would have come out of a late 79-82. The horn button emblem is the design used in 77 and 79, but the steering wheel is an aftermarket piece. The door panels are 69's though.
The nose on the car is from a 75-79 Corvette, with the fender and nose flags being those used from 77-79. The hood looks like an 80-82 and the rocker moldings are 70-77's. The molded in front spoiler, is not GM either, but instead was added by a previous owner. The painted sport mirrors are from a 77-82 also.
Unlike Vettebuyer though, I think the shifter may be original. Because of the design of the 77-82 console, the 77-81 Corvette used a taller shifter handle, then 68-76's. The shifters are identical, except for the height of the handle itself. When you use an early shifter, in the later console, the shifter ends up looking very short, because of the taller console.
I hope this info is helpful.
Received 1,468 Likes
Cruise-In II Veteran
Having been used from 69-80, the 010 block is one of the most common Chevrolet blocks, but I don't believe it was ever used for 305's.
The old Holley is going to be retired and a 750 Quick Fuel will take it's place on the old Edelbrock Scorpion manifold.
All your info on the body confirms Vettebuyer's observations which indicate it has been modified with bits and pieces from later models.
My son paid $25,000AU which is about $18,000US for it and although I think it was a bit too much it's $10,000AU less than what the seller wanted 2 years ago.
Cheers.
rossi.
