Bob's 1969 Resto-Mod Build Thread
Those pictures were taken in Twentynine Palms, Ca when I was stationed there. Not too far from Apple Valley.
It's going to be a lot of body work One step at a time.
Oh I am! I am being careful to label everything that isn't obvious and bagging all hardware and attaching to the part it came off of. Its tedious, but otherwise reassembly will be impossible!
restore
Hey Bob looks like a lot of bondo instead of laminate material in some of those pictures. I think you mentioned that you have new quarters or was it just flares. Evercoat VPA (vette panel adhesive) will help in some of your body work. Try using laminate instead of cloth. Looks like a busted ear of the rear housing. Well you certainly have your work cut out but you are in the right place for when you may need help.
Carry On!
ZIO
Carry On!
ZIO
I started stripping paint. I'm very ADD when it comes to this kind of stuff, and I didn't get a very good system down while I was in CA. I just kinda skipped all over using a combination of stripper, razor blades and sandpaper.
I practiced on areas I knew were going to get replaced
Had a bit of a hanger left over of the piece of fender flare.
Hopefully this will be smaller and patch-able when the fender goes back on
Safety Selfie!
Got it!
Safety Selfie!
Got it!
Carry On!
ZIO
Carry On!
ZIO
Good news on that busted ear is the car came with a replacement!
Center of this picture
Looking forward to your advice on bodywork!
#33
Nice
I'll be following this one, good luck. BTW - Where in Virginia are you?
https://www.corvetteforum.com/forums...d-project.html
#35
First nice to have another Marine on board, second where did you end up in VA, I work in Quantico and reside in Stafford and third here is my build to add to your collection.
Last why Navy 08 with the Eagle Globe and Anchor?
https://www.corvetteforum.com/forums...post1590367398
#36
We are neighbors practically! I've seen your project before, I overlooked it when I was making my list. It's over in Tech, not General.
#37
Nam Labrat
Received 4,179 Likes
Good job of documenting with pics!
#38
paint remover
You can also use a heat gun and scrapper which was very effective and fast. Then come back and sand with 80 grit. The red primer base can be removed with automotive lacquer thinner and a scuff pad when your ready.
ZIO
Just saying!
ZIO
Just saying!
#39
How high did you turn up the heat gun? I only had luck on certain surfaces with it.
#40
