Oil "TEMP" gauge..
Oil "TEMP" gauge..
I have an 81 and it has an oil TEMP gauge that is not working. Can someone tell me where the sensor/sending unit is for this gauge. My oil pressure gauge works fine. Thanks for any help.
Also, what is a normal operating temperature for the oil? I now know the gauge is good, I grounded the wire from the sensor and the gauge went all the way up. So, I gusee its time for a new sensor. TIA.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
What is the gauge doing? If it's pegged full hot the sender wire is grounded out, if it's all the way on cool then the wire may be off. To test the gauge remove the wire from the sender and ground it out... see if the gauge goes to full hot. Then let the wire hang not touching anything and see if it goes cold.
If you get the reaction above from the dash unit then replace the sender.
If you don't... then go to the back of the dash unit and make sure the connector is snug and clean. If it is, test the power wire for power using the ground on the connector.
If you have power you have verified both power and ground and you may possibly have a bad gauge. If you don't then use a different ground to isolate the problem.. you can do this by switching ground and testing for power.
If you can't figure it out, post back.
Willcox
Willcox
Oil "TEMP" gauge..
I don't know about normal, but my '81 (with all the computer and emissions stuff off) runs just a bit above 250 on the gauge when fully warm. Basically the tip of the needle sits between the "5" and the "0" in the "250"...Pretty much the 12 o'clock position.
Willcox
Willcox
THANK YOU! with your help I have determined that the gauge is OK and I need a new sending unit.
Mine runs about 20* below water temp, unless I am driving hard, then they are about the same.(We did a Death Valley run this year).
Depending on where the sensor is located, oil temps should always be somewhat higher than the coolant after running for a while. Same as when the oil pressure drops after a while. The most accurate spot for a sensor is in the oil pan.
