torx size for seatbelt removal???
T47 Torx is out here I have it in my sleeve of Snap-On sockets.
https://store.snapon.com/TORX-174-Sp...7-P636916.aspx
I will write this.....DO NOT ASSUME that these Torx bolts will come out easily. Being at the door jamb...and depending on the year model....they can get seized in place. And the LAST thing you want to to cause the square nut that it welded to the floor pan to spin and break free. The Torx bolts at hand brake area are generally not an issue due to rust....but the threads on the underside and get all clogged up with crap...so ...do not assume that they will come out easily.
DUB
DUB
DUB
DUB
DUB
DUB
What will get a person attention faster than anything is that when they are using a tool and it fails and then damages the fastener that they are trying to get out....and then spend hours trying to get it out...further damaging it. When having a quality tool would have more than likely worked in the first place. I only am writing this is because I have LIVED this scenario...and I know the difference....and got taught a valuable lesson from the 'school of hard knocks'. So if the difference in cost from one socket manufacturer to another is 20+ dollars.....well if I spend 20 minuted fighting with getting the fastener out due to using a lower quality tool that is failing or damaging the fastener...I am LOOSING money. I know most DIY'ers do not consider their time into the equation for a repair....so my perspective is a bit different because I have to consider my time. Obviously...use what ever tool that you feel will work for you. I am NOT trying to push Snap-On...just using it as an example.
DUB
Dub,
My Father was a mechanic many years ago (like 70) in the military before he was promoted to the commissioned ranks. He died in the late 1960s. I have many of his tools. You can't break them! I don't know what brand they are.
Snap-on and craftsman have the same lifetime guarantee. Only with craftsman you are guaranteed to use the guarantee.
the torx tool (45) is most likely going to strip the bolts on the outside no matter what lube product that you douse them with. Douse it anyway. That's Just how it is if there is even minor rust. Even vice grips or a pipe wrench and a torch will be hit or miss.
I ended up buying a drill-mounted cutting wheel from my auto parts store for two bucks. I cut two sides into it that I could get my vice grips to bite on. Then, upon re-installation I put the inside bolts on the formerly seized outside bolts because they are visible, unlike the inside bolts which are hidden below the seats. I installed new, hardened steel bolts and copper sleeves (to keep the exposed threads from contacting the female belt) from my local hardware store.
The carpet went in well. Good luck.
Dave
Dave
I can tell you that older Craftsman Ratchets break all the time. Screwdriver blades twist and snap. I only saw a few cracked sockets and not a single broken combination wrench.
For the lighter duty stuff (small screwdrivers, 1/4 drive ratchets) I could never justify what Snappy charges. I also despised the fact the salesman just made up his own prices. (New guy= highest prices)
But, Ill say this....Craftsman products have gone to **** in the last 5 years. They have begun selling non warranty tools cleverly hidden among the regular stuff. They have even rescinded their 'lifetime warranty' on such hand tools as tape measures. (Take a lifetime tape back to them and you get a '1 year' warranty back in exchange.) Add to this the fact that they are closing stores left and right.....Im wondering what Im going to do with all my Crapsman stuff in 10 years when they have gone bankrupt....
Man-oh-man. I am a 'tool *****'. Old tools made back in the WWII era and shortly after it are something that I really like. I have some old tools that are my prized tools. They were built stout.
DUB
Craftsman's older ratchets, with the "twist the top" to reverse, are super strong. Then they came out with the new, pretty polished chrome, little lever to reverse one's, that are NOT that strong.
I worked in maintenance in an automotive parts plant for 34 years, until it was closed in 2007. We had to rebuild a lot of Snap-On half inch drive ratchets at work for everyone there.
I was at Sears a couple of times and people would tell me that they would purposely break a good Craftsman tool, just to get a brand new one.
I think EASCO made the good ratchets that I talked about, for Sear's. Lou.
My tools are not terribly organized as I can't wrench as I used to do. Time takes a toll. But these examples are many years old. When is the last time you saw a vice "Made in England"?
I find the quality of Snap On tools the last few years to be real garbage, they are making a lot of stuff in China now, sad really. Sold now at Sams Club, Ace Hardware, all branding based now. I have switched to Mac tools and have been happy, good quality.
Craftsman has been crap since the late 90s, all from China now. I worked at a Sears Hardware store and was able to buy at great prices the older style "quality" stuff they had. Do you guys remember that the sold ratchet rebuild kits for 1 cent, most guys would buy the rebuild kit, rather than exchange for a new one. I recently turned in a bag of broken Craftsman tools I had and exchanged it for the "Crapsman" style now.
But I got to say the Snap On socks though are really good, especially if you wear work boots all day.
DUB
