Question about a 1980 Corvette VIN #
I am looking at a 1980 L82 Corvette with a 12 digit VIN number. The first 2 digits indicate a "12" not a "1Z". My understanding for VIN numbers on the 1980s should be a 13 digit number and all VINs for that year begin with a "1Z" designation. I have obtained the VIN number for this vette and verified that it is registered under a 12 digit VIN with the 2 begininng numbers as "12". Can anyone explain how this is possible or is there something terribly wrong here?
Where do you see the "12" on paperwork or on the actual VIN plate attached to the car?
It is not uncommon for DMV paperwork to change the "Z" to a "2" due to a typo.
Received 1,468 Likes
Cruise-In II Veteran
Check the VIN plate on the driver's windshield post and the vehicle certifcation label on the driver's door.
I have not seen the actual VIN on the car yet. I was planning on seeing the car in a few days but wanted to check things out before I go look at it. I figured it could be a typo but I am being told the car only had 2 owners and the current owner has had it for over 15 years. I am just not sure how some car owners don't have everything documented correctly. The vin still seems to be short a digit but I am surprised the DMV did not catch the 12 digit VIN. So far from what I can see this C3 looks in very good shape with a clean title.
Thank you for the replies everyone. So can it be a 12 digit number or does it have to be 13? Just want to confirm. Thanks
Dmv
Check with your DMV, suspect they would have to make a visual inspection of the VIN. In my case I was registered in NY and the "S" in the serial number was a "5" on the paperwork. When I filled out the paperwork for transferring to CT I corrected the error and nobody ever questioned it.
It's quite common for a DMV's to mix up S's and 5's, and 2's and Z's, but normally they should catch a VIN that's a digit short.
From my experience, all that is needed in NJ to correct a title mistake, is a digital photo of the VIN tag, and a notarized letter explaining the problem. Each state has their own regulations, but it shouldn't be to hard for the seller to do.
If the seller can't or won't go to their DMV, and do what's necessary to fix the title, then you should walk away from this deal. It will be much easier for the seller, as the current owner, to fix the problem, then it could be for you to try and fix it when transferring the title into your name.
