Front speaker recommendations for 1980 . Mine are disintegrated .
I have a 1980 with an aftermarket pioneer radio circa 90's or so . First the front left speaker went out on me and today the right side went out .
Right now I just want to change out the front speakers which are Pioneer coaxials that are just disintegrating .
I went online and saw Pioneer coaxials but would rather get advise and possibly some model numbers so I get the right pair .
The bolt next to the windshield looks like it might be a PITA to get to .
Any advise there would also be great .
Down the road I will change everything out . I just have other things I would like to address first ...
The original speakers were just standard 4x6's. I'd buy what ever ones you like. The only issue you may run into is the magnet. The OEM Delco speakers had a rather small magnet. Most aftermarket speakers have a larger magnet, requiring a little playing around to get them to fit.
It's been years since I pulled speakers out of a dash, but I don't remember it being to tough to on bolt them. Depending on the fastener holding yours, a ratchet or 90 degree screw driver should be all you need.
GM Cert Corvette Tech
Pro Mechanic
The front speakers are a 4 x 6. Believe it or not they are pretty easy to get to. I have found after numerous front speaker changes that I like a full range speaker in the front. The 4 x 6 co-axles sound to tinny. The full range gives you better clarity in my opinion for the front.
Now for that one little screw next to the windshield, I use a quarter-inch shallow socket and grip it with a pair of pliers to get the screw loose and then I walk it out with my fingers.
Full range speaker , meaning woofer , coaxial , tweeter ???
Pro Mechanic
Once you start putting a speaker on top of another speaker as coaxles and triaxles are designed, you lose the base of the speaker and just wind up with a distorted sounding midrange and tinny lows.
Full range speaker meaning just a woofer....No Coaxial No Triaxial
Just like these
http://www.ebay.com/itm/BOSS-Audio-BRS46-Replacement-Speakers-4-x-6-50W-Full-Range-Speaker-/321840255515?hash=item4aef2c921b
NOTE: Even though the Polk Audio MM461P are co-axles, the speakers are not resting on top of each other so you still get the full rich sound of the woffer
http://www.ebay.com/itm/POLK-AUDIO-MM461P-2YR-WRNTY-4X6-300W-MARINE-FULL-RANGE-CAR-STEREO-SPEAKERS-SET-/171820179553?hash=item280147e061
I went with Kicker 4x6's and they sound amazing...also have 4x6's in the kick plate 3" kickers in my Fiero headrests.
Having an 8" sub in the jack box really rounds out the sound. The entire car still looks stock inside (except for the amp rack on the back wall which is hard to see from the outside).
Ken
Ken
Hey everyone , I went with the kicker 4x6's because the template looks about the same as the old pioneers I took out .
A few good ideas here . I am thinking about a sub in the jack area and mounting an amp in the back of the hatch area .
The custom box along the rear sounds nice also .
When I am ready , I just want to get some decent sound , nothing crazy .
Kenwood or Pioneer head unit , small subwoofer , couple of decent 6x9s and a decent amp .
Just like these
Boss Audio BRS46 Replacement Speakers 4" x 6" 50W Full Range Speaker 791489110389 | eBay
Polk Audio MM461P 2yr Wrnty 4x6" 300W Marine Full Range Car Stereo Speakers Set 747192114480 | eBay
Just like these
sound is no longer my top priority, so anything with polypropylene, butyl rubber surrounds, 1" voice coils , piezo's is just fine with me....
and i have had good luck with Pyle Drivers in the past
next perhaps a head unit, with no subs and no amps and no rear speakers ( i deleted those, they were loose and will be projectiles in a small crash....)))/////
Pro Mechanic
https://www.corvetteforum.com/forums...r-storage.html
Ken
If you want an idea for the sub box have a look at mine.
Ken
Ken
I am going to bite the bullet and go to the local stereo shop and have them toss in a pair . This should also make a big difference .
My next step would be to get a new head unit with a sub but that will have to wait a while .
Boy this stuff gets addictive ... Thanks again .
Chris
Yes it does.
A Previous owner cut holes into the back wall for the speakers and installed plastic bags to keep the water out (or maybe an stereo shop did). After fibre glassing in the holes I decided to put a false wall across the back to mount my amps. Everything looks like it is mounted to the back wall but it isn't.
From here you can see the initial set up.
I am looking for a matching Sony amp for the right hand side...Then the left 4 channel amp will be for the Front upper 4x6 Kickers and the lower 4x6 Kickers.
The newer right amp will be for the 3.5" Kickers in the headrest of the Fiero seats. The leather just arrived from Mr Mikes last week and I have not had any time to work on them yet, to many outdoor projects have to get wrapped up before it gets much colder.
I built some wall plates and riveted them in before mounting the speakers.
I may use the Alpine Amp for the sub but I am running out of room on the back wall. Maybe in the center compartment beside the sub? Not sure.
Yes you can say I am addicted. I have had the car for 3 years and this is the first year I have spent any decent money on it. I am sick and tired of fixing everyone else's cars in the family and not having any money left over for Violet. This year and next will be different.
Ken
BTW, the amp and deck were FREE. I have a Sony Master card and I used my points to get them. The Alpine I have had kicking around for 20 years...they are like 35.00 on ebay these days, almost bought another one from a guy in TX last year. The 4x6's were on sale last year for 1/2 price. The 8" Infinity sub came from my wife's Tahoe before we sold it, I paid 99.00 for it 4 years ago...again on sale.
Overall I think I have spent $300.00 on new parts/speakers for this car...it was all labor.
I may be addicted, but I'm also CHEAP
Ken
Yes it does.
Ken
Ken
The head unit I want is only $109 and the rear speakers are $105 but I will probably spend the same amount in labor just putting those items in .
Thanks for your info ... Chris
