Who's familiar with 1975 Fusible links at the starter?
Working on a 75. I happened to notice that the insulation on the fusible link by the starter was cracked pretty badly. It looks like there are 2 fusible links (red/orange?) that connect to the starter. Is this correct? It looks factory. What's the correct gauge to replace these with? The one with the cracked insulation seems to be a bit heavier gauge than the other. Anyone know of specific GM part #'s?
Auto Zone carries these. Anyone have a better suggestion?
If it were me, I would simply 'adjust' the routing of those links to where they were not rubbing on other metal items and leave them alone. If you are concerned about their appearance, brush a little diluted dye or paint onto the insulation to recolor the wires.
You have original equipment which is apparently working just fine right now. If you replace them with aftermarket 'stuff', you may create other wiring issues, in the process. I think I would leave well enough alone on this one.
There are no specific part numbers of these fusible links. Because they are made into the harness. IF you plan on doing this...you MUST replace them with the correct gauge as you know and LENGTH also. I would have to look at a wiring diagram to confirm the gauge sizes are correct.
100%
Clean up the wire and wrap it with some electrical tape to seal up that split in the insulation. But do as you wish.
DUB
DUB
