How much is your "prom queen" costing you?
#42
C3's seem to be a work in progress. It's a love hate relationship, hate to spend the money love driving it. I try to do as much as I can and have time for.
#43
Would that cost be in time or money?
Time: In the almost one year since I was presented with a licensed, running '79 with about 50k on the clock I've spent at least 70 hours turning+cleaning and 60 hours learning+sharing. Will go up on jack stands for the winter where I expect 30+ hours for minor (I hope) fluid leaks, differential lube replacement, parking brake repair, cleaning and replacement of as many rubber suspension components possible without serious disassembly. Another 15 hours to replace a few sections of vinyl and fabric in the seats and door panels if the available replacements prove near perfect matches.
Money: 9K as presented to me to include 2.5K above auction cost. Since then 2.5K in parts and $350 for labor to reset the windshield and replace the A/C accumulator. A/C still not working and I suspect at least 1K. $100-$300 in parts over the winter that may turn to 1k+ ; In sum about 13k to date with 14-15k expected for it to be completely functional, in nearly original state and reliable enough for me to take it on its' first real road trip for a few nights and more than a thousand miles. Yes--I intend to drive it!
#44
Dementer sole survivor
Received 6,284 Likes
2016 C3 of Year Finalist
#45
I have had the car almost 10 years now...
I have a second envelope equally stuffed...probably could have bought a C6 by now LOL
I don't mind though, have had great enjoyment over the years
#46
cost? what cost?
I $tarted thirty year$ with hor$e$ and then added working with $everal RX-7$, $o I don't under$tand why people are concerned about the co$t. Thi$ i$ a hobby. If the FedEx driver doe$n't leave a car part$ delivery for me about every 2-3 day$, my neighbor$ will a$$ume I died.
RA
RA
#51
I know exactly what the old broken down **** Star is costing me. A lot of the work I did myself, some I paid to have done, and some was a combination of the two. What's listed below is actual dollars spent out of pocket. Some of you may have seen this before but it's up to date as of this morning when I put the car into storage for the winter.
1970 Chevrolet Corvette Coupe
Build date May 25, 1970
Date: 8-20-2011 Mileage: 56,200 Cost: $150.00
Battery NAPA 75 month
Date: 9-9-2011 Mileage: 56,400 Cost: $344.50
Distributer assembly
Cap, rotor, points
Date: 9-18-11 Mileage: Cost: $77.90
New door locks W/keys
New gas cap
New wiper blades
Date: 10-13-2011 Mileage: 57,877 Cost: $171.17
Lube, oil and filter
Radiator flush
New radiator cap
Replace anti-freeze
Date: 12-2-2011 Mileage: Cost: $769.00
New parking brake console
New loop carpet
New vinyl seat covers
Date: 12-7-2011 Mileage: 58,552 Cost: $1492.23
(4) New Brake calipers
(4) New Brake lines
New power steering control valve
New power steering ram
New power steering lines
New power steering fluid
New brakes
New brake fluid
New AC Delco starter
Date: 3-14-2012 Mileage: 59,792 Cost: $4793.87
New 350-350hp Motor
New GM camshaft 350-350hp (GM Part #3896962)
New motor mounts
New clutch
New water pump
New clutch fan
New spark plugs
New thermostat
New antifreeze
Replaced all gaskets and fluids
Date: 11-14-2012 Mileage: 64,880 Cost: $29.00
Date: 11-20-2012 Mileage: 65,171 Cost: $373.97
New BF Goodrich TA Radials - Rear
Date: 4-20-2013 Mileage: 67,309 Cost: $722.47
Repack wheel front wheel bearings
Replace right spindle
Replace front wheel bearings and seals
Date: 5-20-2013 Mileage: 68,600 Cost: $1790.00
New paint
Date: 9-13-2013 Mileage: 69,005 Cost: $29.00
Date: 9-13-2013 Mileage: 69,010 Cost: $10.00
Fram CA136 Air Cleaner
Date: 9-26-2013 Mileage: 69,150 Cost: $65.70
New horns
New horn contacts (steering column).
Date: 10-25-2013 Mileage: 69,287 Cost: $1134.07
Rebuild steering column
New ignition switch
Replace steering ignition column rack
New steering coupler
New rag joint on steering shaft
Rebuilt front end steering
New steering knuckle
New tie rod ends
Date: 10-27-2013 Mileage: 69,294 Cost: $412.07
Replace all weather striping
Replace driver’s side windshield weatherstrip retainer
Date: 10-28-2013 Mileage: 69,308 Cost: $79.23
4-wheel alignment
Date: 10-31-2013 Mileage: 69,312 Cost: $62.00
Replaced tail light lenses
Complete with gaskets and screws
Date: 11-15-2013 Mileage: 69,320 Cost: $95.00
(4) Stainless steel wheel trim rings.
Date: 12-10-2013 Mileage: 69,438 Cost: $29.49
Heater Isolation Valve.
Dahl Brothers Canada LT Valve 3/4crimpex
(MODEL #121-PX5-PX5-BAG)
Date: 12-12-2013 Mileage: 69,438 Cost: $20.00
Restored (painted) nose and gas cap emblems.
Date: 12-27-2013 Mileage: 69,438 Cost: $16.57
Replace Nylon T-Top bushings.
Date: 1-14-2014 Mileage: 69,438 Cost: $95.80
Replace door hinge pin and bushings
Replace door lock ****
Date: 1-16-2014 Mileage: 69,438
Placed car in heated storage for the winter.
Date: 2-18-2014 Mileage: 69,438 Cost: $75.00
T-Top Panel Storage Case
Date: 5-7-2014 Mileage: 69,475 Cost: $58.39
Removed car from storage.
Spark Plugs (AC Delco R43TS)
Distributer cap and rotor
Date: 5-11-2014 Mileage: 69,550 Cost: $63.90
New Valve Cover Gaskets (Fel-Pro #1628)
PVC Valve (Fram FV428 or DuraLast 198DL)
Date: 5-20-2014 Mileage: 69,618 Cost: $119.90
Custom Fit Spark Plug Wires (Accel #5041B)
Date: 5-24-2014 Mileage: 69,644 Cost: $172.92
Lectric Limited Breakerless-SE Electronic Ignition #38131
Date: 5-27-2014 Mileage: 69,660 Cost: $101.97
Front Tunnel bellhousing Heat Seal
Factory Shifter Rebuild Kit
Date: 8-15-2014 Mileage: 70,099 Cost: $1,639.94
New Aluminum Radiator (Dewitt’s Model: 1139070M )
Antifreeze
Radiator Cap
Service Air Conditioner
Convert Air Conditioner from R-12 to R-134A
Freon R-134A
Receiver Dryer
A/C R-134A Retro Fittings
Date: 8-22-2014 Mileage: 70,128 Cost: $1,390.13
Air Conditioner Compressor Kit
Air Conditioner Expansion Valve Kit
Replace PRV valve with Conversion
Flush AC System
Freon R-134A
A/C System Dye
Replace AC Belt
Replace Fan & Alternator Belt
Replace Power Steering Belt
Date: 11-18-2014 Mileage: 70,298
Date: 3-21-2015 Mileage: 70,298 Cost: $96.48
Replaced drivers side door ajar switch
Replaced both headlight vacuum relays.
Replaced vacuum filter
AMD vacuum check valve
Installed Spectre #4284 PVC Valve Breather
Checked rear end gear ratio (3.36)
Date: 3-28-2015 Mileage: 70,310 Cost: $61.30
Replaced headlight dimmer switch
Replace Air Cleaner/Valve Cover Hose
Replaced wiper door vacuum relay
Date: 4-29-15 Mileage: 70,325 Cost: $13.97
Replaced valve cover grommets
Date: 5-5-15 Mileage: 70,335 Cost: $14.02
Replaced miscellaneous vacuum lines
Date: 5-18-15 Mileage: 70,335 Cost: $51.20
Dr. Rebuild Vacuum Line Check Valve
Dr. Rebuild Vacuum Line Poster
Dr. Rebuild Vacuum troubleshooting guide
Date: 6-6-15 Mileage: 70,701 Cost: $105.00
Replaced RH Headlight Actuator
Replaced LH Headlight Actuator
Date: 6-8-15 Mileage: 70,701 Cost: $146.18
Replaced Wiper Door Actuator
Replaced Wiper Door Actuator Boot
Date: 6-15-15 Mileage: 70,836 Cost: $139.00
Dr. Rebuild Deluxe Vacuum Hose Kit
Dr. Rebuild Wiring Guide (Except Dash)
Dr. Rebuild Dash Wiring Guide W/AC
7/16 Vacuum Hose Quick Clamps
Date: 6-25-15 Mileage: 70,836 Cost: $39.21
Headlight Bushing Kit (12 pieces)
Headlight Springs (8 pieces)
Date: 6-29-15 Mileage: 70,836 Cost: $49.48
Corvette Antenna Mounting Bezel, Nut & Gasket
Corvette Antenna Mast & Nut
Date: 7-5-15 Mileage: 70,965 Cost: $186.95
Replace removable rear window and frame.
Date: 7-11-15 Mileage: 70,965 Cost: $29.02
Grease Steering Box
Date: 8-8-15 Mileage: 70,980 Cost: $73.89
Replace headlight on/off switch
Replace headlight switch **** and rod
Date: 8-18-15 Mileage: 71165 Cost: $76.98
Solenoid Windshield Wiper Door Vacuum Switch (back of tachometer)
Date: 8-20-15 Mileage: 71165 Cost: $65.12
Wiper Arm Safety Vacuum Switch (on firewall) (Willcox #5638487)
Date: 8-27-15 Mileage: 71178 Cost: $39.00
Rebuilt (2) Headlight Vacuum Relays (Dave Jacobs)
Date: 8-29-15 Mileage: 71259 Cost: $9.50
Corvette Door Handle Helper Spring (Corvette Central #283012)
Date: 9-4-15 Mileage: 71277 Cost: $82.45
Replace Wiper Door Vacuum Relay (Dr. Rebuild #2771198)
Date: 9-21-15 Mileage: 71286 Cost: $152.18
Lube, Oil and Filter (Pennzoil 5W30)
Rear Differential service (80W90)
GM Limit Slip Fluid (#88900330) – 2 bottles (8 oz.)
4-Speed Transmission Service (80W90)
Date: 11-20-15 Mileage: 71286 Cost: $8.99
Sta-Bil Fuel Stabilizer (#22214)
Date: 11-20-2015 Mileage: 71286
Cap, rotor, points
New gas cap
New wiper blades
Radiator flush
New radiator cap
Replace anti-freeze
New loop carpet
(4) New Brake lines
New brakes
New brake fluid
New 350-350hp Motor
New motor mounts
New clutch
New water pump
New clutch fan
New spark plugs
New thermostat
New antifreeze
New paint
New horns
New ignition switch
New tie rod ends
4-wheel alignment
Antifreeze
Radiator Cap
Freon R-134A
Receiver Dryer
Flush AC System
Freon R-134A
A/C System Dye
Replace AC Belt
Grease Steering Box
#53
I've driven mine a little over 90 miles in the few months I've had it. First came the oil and filter changes, then a battery, then new battery cables, I just got done rebuilding the power steering control valve, a real bargain at under $20. Couple hundred in cleaning/polishing supplies, a few more for tools, and the list goes on. If I had more free time, I'm sure I would have spent more. And I do keep track, because I'm too poor to own a Corvette.
#56
Funny.
I looked at your list and said to myself, "He has WAY more than me into his car."
I added up your numbers very roughly and it's nearly $18k.
I've owned my 1970 for about the same amount of time (Jan 2012). I could get my wife to run a QuickBook summary, but my back-of-the-napkin guesstimate is that I've spent about $13k in that amount of time.
And you've touched many components that I have not.
So...the list looks scary, but in the end it's just about right. You're right on par with my experience of what it actually takes to keep one of these vehicles on the road.
Unfortunately.
Unfortunately.
The following 2 users liked this post by Detroit Steel:
keithinspace (11-24-2015),
Rescue Rogers (11-24-2015)
#58
Great thread. Thought the front page crowd would appreciate as well...
https://www.corvetteforum.com/articl...snt-cheap-huh/
Happy Thanksgiving.
#59
I recently shelled out 7 grand for all the parts to assemble a new gen 1 sbc...not a single GM part in the build. Well one if you count the OEM coolant sender. The last engine was getting tired after 23 years. If I did everything right it should last me the rest of my life. Nobody can say I'm not doing my part to stimulate the economy.
What's the opposite of prom queen? Cause my car rides like a stonepile, reeks of gear lube and Sunoco 260 unleaded and the lacquer paint attracts brake dust like nobody's business. I'd be embarrassed to denote it of the female persuasion.
#60
I used to keep track of all the things I bought and did on my '72. It was kind of fun to do for awhile, anyway. I initially spent $4,250 for the car in 1974 and then another $250 for the hardtop. Since then, it's been all the typical maintenance items that you'd have to replace on any car that you own. I've done batteries, tires, brakes, calipers, exhaust, bulbs, oil changes and filters, etc., etc. and the list goes on. It's just all part of owning a car, no matter what make or model. Maybe after 41 years I have a total of under $10,000 in the car and just turned 60,000 miles this past summer. She still looks darn good for her age and doesn't suffer from rusty mount syndrome, birdcage crumble, and all the other problems I read about on the forum. I guess I'm pretty lucky she's still a hot, little looker.
Duane
Duane
