78 cold air duct
78 cold air duct
I ordered this from Corvette America & there is no way with the metal bands it will stretch to fit air cleaner or cold air duct. P/N 23059 . 1KH1160EA says 76- 81. Can anybody help with one that will fit? Thanks
Received 1,469 Likes
Cruise-In II Veteran
Do you have the stock air cleaner can?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Dave-
You should release the lever, slide it on the air cleaner and then push the lever down tightening up the hose to the air cleaner. It's very very tight the first time but it should close.
There is only one manufacturer on this part right now so there isn't an alternative. If it won't install per above, possibly you got a defective one.
Willcox
Willcox
Dave-
Willcox
Willcox
Former Vendor
Willcox
I even cut the clips to see if then I could get it on no go even then the vinyl was all folded in side the openings on both ends folding it out didn't help. The one in the picture was gone when the car was delivered to me.
[QUOTE=Willcox Corvette;1590979209]Dave-
I looked it up & I bought this defective one from you order #100002057
The others you have may be defective also. Any way you can check do you have an 78 air cleaner to test fit it on?
Thank you Willcox
[QUOTE=dobedave;1590984958][QUOTE=Willcox Corvette;1590979209]Dave-
Willcox Corvette sent me another one and it fit perfect , they will be my #1 Corvette parts supplier from now on. Thanks
