Weight loss program for my c3
I removed and weighed the following
spare tire/rim 35lbs
rear speakers 4 lbs
radio 5lb 5.2oz
heater core 2lb.7 oz- new 1lb.3oz
pass visor 1lb-1.5oz
driver visor 1lb
jack and handle 8lb 15.9oz
spare tire tub 12lb 14oz
fan/clutch 5lb 5oz
rubber spoiler lip(damaged) 2.5lbs
removed but not weighed: do you know?
rally wheel center caps~ 10lb
shroud ~20lb
pwr seat tracks and switches~15lb
weight increases
alternator 13lb 4.2 oz old 11lb 14.6 oz
manual seat tracks 6.51 lb
new radio 2.5 lbs
taurus e fan ??
what else can i remove?
do I really need my battering ram( bumpers?)
did the chrome bumper cars have this 5mph stuff?
rear speakers 4 lbs
radio 5lb 5.2oz
driver visor 1lb
fan/clutch 5lb 5oz
shroud ~20lb
weight increases
new radio 2.5 lbs
taurus e fan ??
Received 6,943 Likes
2015 C2 of Year Finalist
If you remove the engine and trans you will save about 1000 pounds
no just a street cruiser
i can already feel the difference on the street with 100 lbs gone
i don't need to go crazy, asking for some not so obvious junk i can remove for free
i read about BJ's crazy stuff like front air canister 45lbs, which i don't have and the rear battering ram, which i intend to keep
I like the idea of lightening my Corvette, and I may take out the spare and jack (Platinum AAA, tows 200 miles), but wow, 1 lb for the driver visor, that is HARD CORE!
I used to backpack in the Colorado Rockies, carrying an 80 lb pack. We went so far as to cut the handles off of our toothbrushes to save 1/10th of an ounce.
If you have a moment, I am curious as to what the spare tire tub weighed-
Thank You-
-Ray
Thank You-
-Ray
Thank You-
-Ray
Thank You-
-Ray
rear speakers foamed went away in the 90's that had to go.
when i get a chance I'll try to weight the tub, it feels light the jack which i weighed around 10lbs
Or start with a smaller car. I have hauled a couple hounded pounds of stuff in the trunk of my Chevelle and never noticed it was slower or could tell it was back there. I'm not sure what why anyone would care for a street driven car that is not going to compete
When she gets in the car, I feel NO difference whatsoever than when she gets out.
Think about it like that.....does the addition of a passenger SLOW you down? Then the removal of 100-200 LBS is NOT going to give you any felt difference unless you are making serious suspension mods.
Just my .02, not looking to offend, just looking at this realistically.
After market hood and nose saves 45 pounds ,
Headlight system saves 25
Targa top cuts 12
After market breaks 88 pounds
Rear tire , carrier and jack 63 pounds.
Tubular control arms 12 ,
Heads , intake an easy 50
Cruse control, a/c with delete cover another 40 or so .
Chrome molley trans cross member 17.
If you have steal springs go composite save 50 .
402 pounds gone ,
I call it Jenny Craig for a corvette on steroids
Targa top cuts 12
402 pounds gone ,
"i bought the car without the driver visor and was not going to replace it and with so little room head or otherwise in the car, i figure the stupid passenger with the "vanity" mirror getup is just as insane to leave in there, and frankly it cleaned it up nicely, the lights didn't work it was a mess.
when i get a chance I'll try to weight the tub, it feels light the jack which i weighed around 10lbs"
slickfx3, thank you-
-Ray
-Ray
-Ray
-Ray
~13lbs with road grime
Targa top cuts 12
402 pounds gone ,
Targa top cuts 12
402 pounds gone ,
So I see you bought a targa top? I was going to call you this summer about selling mine but I just couldnt part with it, even though I havnt used it since I bought those T-Tops from you.
My wife weighs 107 lbs.
A friend I met years ago here in Florida, moved to Nebraska, I think, and so he/I keep in touch.....his handle is 69427 Mike......and he is into competition with his car....and has shaved it down to the 2800 lbs region if I remember right......
want to try looking him up here, and if not, send me a PM, and I can give you his contact info......
he is a retired GM engineer.....I used to kid him about filling the frame with helium would make it weigh less.......
Interesting point. Lets say you fill the entire car with helium. It will "weigh" less but the mass will be the same, so there would be no effect on acceleration. Acceleration = force/mass, not weight. I'm sure your engineer buddy pointed that out.
Go to some aluminum parts:
Radiator, water pump, heads.
Also lightweight wheels will really help. The reciprocating weight reduction does more then the usual 100lbs = .1. I've tested this on both of my cars.
Just light weight skinnies on the front alone is 1 tenth reduction and 2 mph gain on my 71. It's a reduction of about 45lbs.. I've tested this at the track, same day, A-B-A test style.
On my 02, my drag wheels knock off 70lbs of spinning weight, I definitely can feel the difference on the street during hard pulls.
Well, you DO have somewhat of an advantage with that shop of yours. But in your case, you've built a pro-street car. The OP doesnt seem to have such extensive modifications. 400 LBS makes a difference...100 lbs isnt even noticeable.
That aint my shop I may cut out the front cross member after I do the 4 link which will eliminate the rear cross member , and use chrome moly tubing in there place should save 100 or more pounds and strengthen the chassis
How ya been any word on your car getting done ? I know of a mint 1980 frame in webster
