It arrived! Corvette stablemate
#42
that fuel injection just looks right!
#45
Received 3,218 Likes
#46
I can't take credit for all of it as it was a partial build when I bought it but I am upgrading quite a few items. The distributor is up front because it's easier to work on there. Took a little work to get it there but it's working good in that spot for some reason.
#47
Just a quick update. I got the cam back in and got it running just to make sure it is all working. Now it's back apart somewhat. Starting the fuel injection install.
No turning back now. New plug wires, I have all the fuel lines pulled out and am replacing them with the correct ones. I have the Ecm next to the passenger seat and running the wires in the tunnel up to the motor and sensors. Takes some thinking and rewiring to get it all to fit. The cobra is a small car, putting 10 lbs of poo in a 5 lb bag. It's coming together. Lots of rewiring and getting it all right.
Had to get new front brakes in order to clear the new wheels. Big guys.
Also everyone needs a set of custom billit door hinges. The doors are flyweight but the stock hinges look terrible. These will work nicely.
#48
I was expecting a real fight with this. The car had been registered in Florida as a 65 so I brought all the paperwork into DMV. I went at an off time and went through no problem. The guy asked me is this a daily driver. I said nope maybe 1 to 2K miles. He said why not get the QQ plates. I said I did not think I could get them Immediatly. He told me the way to do it and I have to go to a certain DMV but I will try. The guys on the Factory Five forum said there is a red flag for FF cars. I can try but it does have plates as a 65 Factory five roadster.
Just an update I am redoing quite a bit of wiring also. Changing some of the dash and console panels. Should clean up wiring and look better. It is time consuming though.
#49
#50
Thanks. I'm convinced, I think I'm slowly going to start shopping around for one and see what I can find already assembled, instead of taking the long (and expensive) road of building one. I just have to find one built with the deeper footwells and seat for a tall guy since I'm 6'2", but I think a lot of guys build them that way already.
#51
#52
Thanks for the info, I think I have a little more confidence that I can find one I can fit into knowing the chronology of the footbox on the FF's. I had originally thought building my own car would be necessary to make sure I could build it to fit my tall frame, but seems like that might not be the case if I shop around enough. There is a cobra (non FF) in a used car dealer showroom near me and I couldn't even get my legs under the dash, but it was a big block car with a 390 FE motor so they probably had to sacrifice leg room for the bigger motor.
Buying a complete car is a better situation with the wife then buying a kit, ironically. If she sees it roll in the driveway a completed car it's much better than a bunch of parts over a few months time. Also I think it's cheaper to buy a finished car if you get the right deal on the right car.
One more question about your car, is that a power steering pump I see?
#53
Yes it is power steering. Most of the guys who have built more than one always put in power steering on the future builds. It is a light car and does not need it but if you can why not. Little easier in a parking lot. Heck some guys put in heat and even AC.
#54
I have gotten quite a bit further along in the build now. The body was taken off and I went out with it to the painter and spent a few days doing the grunt work of sanding down the seams and getting the rough work done. It was a real learning experience. I am picking the body up this week as it is in epoxy primer with all the really rough stuff done. Here it is right before heading to the body shop with the seams filled with HSRF. Nasty stuff!
The new dash layout. Put everything on the dash and will go with a blank console. This will be nice to on occasion put the screen for the EZ efi on so I can see it while driving.
And the needed picture with the Vette. Went go carting with it around the neighborhood. Just rediculous power
A little video of it being fired up
http://smg.photobucket.com/user/72re...91091346749272
#55
Project is right!
Seen this at the last BelAir gathering, realy nice. A little inspiration..but you don't need it!
Gary
Gary
#57
It's funny how a car that just kicked Corvette butt in the 60s, is now so loved...and respected by vette owners.
Gordon, that is a heck of a "go kart" that you have there! Let us know if you take her to a track day!!
#58
This was my FFR that I sold to get my Vette, FFR3619k. Great fun building, but I got caught out in the rain once too often and decided to get something with a top!
#59
