Plug identification. 1977 corvette behind speedo
Old 12-05-2015, 03:57 PM
Cpdenton
Cruising
Cpdenton's Avatar
Default Plug identification. 1977 corvette behind speedo
I have a plug that isn't being used right now. I am trying to figure out where it is supposed to go.
It has an orange wire going back to the fuse panel. 2 white wire spliced together on one terminal, and a Wh/black wire on another terminal.
Old 12-05-2015, 04:23 PM
jim in oregon
jim in oregon's Avatar
Perhaps a connection for the alarm system?Jim
Old 12-05-2015, 06:52 PM
Cpdenton
Cruising
Cpdenton's Avatar
Maybe, if this car had an alarm, it is long gone! Lots of jack leg stuff going on behind with the instrument lamps. Ended up blowing the fuse for them last time I drove at night. Cleaned it up quite a bit today and heat shrank all the splices. Should be much better now.
As you guys say here, bubba has been in there pretty deep, and now I am trying to get it right.
Old 12-05-2015, 06:56 PM
Cpdenton
Cruising
Cpdenton's Avatar
After finding this picture, perhaps the interior lights are supposed to have some sort of delay module! Mine shut off as soon as you shut the door. I think it might be this transistorized module on the right side of this schematic.
Old 12-05-2015, 07:08 PM
jim in oregon
IF you have the car's 77 owners manual there's a good description of the features and accessories as well as a chart for fuses, what they are and what they protect.
My 78 had an alarm activated by the driver's side door lock( counterclockwise armed it)
Look under the hood, Driver's Side tucked down deep under fender and SEE if the alarm horn is down there..Mine had the orange wire as a hot wire..
The alarm, courtesy lights and clock were all on the 20 amp SFE fuse top left in fuse block..at least in my 78..Jim
Cpdenton (12-05-2015)
Old 12-06-2015, 09:08 PM
persuader
persuader's Avatar
That plug is for the courtesy lamp timer relay.
Cpdenton (12-06-2015)
Old 12-06-2015, 11:09 PM
Cpdenton
Cruising
Cpdenton's Avatar
Thanks. I see no real reason to try and hunt down a replacement timer. This car is quite customized and nowhere close to an original restoration.
I think I might just remove this extra plug altogether, and fix the wire tap splice that makes the courtesy lights work.
Old 12-07-2015, 01:50 PM
Giant_Robot
Giant_Robot's Avatar
I have a 77, and this is indeed for the timer for the interior lights.
I removed mine and the interior lights turn off instantly.
Old 12-07-2015, 03:58 PM
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Douglas Mariani's Avatar
Timer for the interior lights
Old 02-03-2016, 09:19 PM
flyguy767
flyguy767's Avatar
I want to remove my timer. How do I make the new connections to make the courtesy and dome lights still work, but with no delay?
Old 02-03-2016, 10:12 PM
bruiser
bruiser's Avatar
St. Jude Donor '15
You just disconnect the socket from the harness, then connect the two white wires together.
To Plug identification. 1977 corvette behind speedo
Quick Reply: Plug identification. 1977 corvette behind speedo
