under dash work = hard (for me)
1969 corvette L46 with AC
I am trying to put my interior back together.. starting under the dash .. specifically on the driver's side.
Those of you who have this experience please help.
Do I put the duct in first? I assume it goes behind the column.
Or.. do I make the connections to the lower dash bezels (lights, tach,speedo, etc) first then put the duct in?
It's sort of a mess.. I attached the harness to the upper cross member to get it out of the way .. this might be a temporary attachment .. not sure..
I'm struggling with this..
Column is dropped .. still attached to the rag joint.
Here's a photo of what I am working with .. duct and lower dash panel not shown..
I don't have any experience with your year model. I can tell you that I usually end up taking out the front seat and sometimes the steering wheel just to access all of the under dash items. A PIA. Good luck.
Received 1,468 Likes
Cruise-In II Veteran
FWIW: nothing goes behind the steering column. The AC ducting should run under it.
Pull the column. A few bolts on the firewall and the rag joint and it's out. Believe me, it will be much easier, with it out. And there's nothing easy about putting the dash together either. It takes patience and perseverance to do it.
https://www.corvetteforum.com/forums...lonoscopy.html
I would rather have a colonoscopy than work on the dash of a C3 corvette. I have had many C3's and I know that there are many things that are much harder to work on than other classic and muscle cars such as Chevelles , GTO's , Mopars , etc. , but the dashes were the most poorly designed part of the C3. On the drivers side where everything is crammed in everything has to be perfectly in position to get the dash panel back into position causing a real pain in my a** , thus I would prefer a colonoscopy for which I experienced no pain. Unfortunately I'm going to the garage right now to finish the dash which explains this rant.
Received 2,878 Likes
Hi b,
Do you have the 69 AIM to refer to?
I can't imagine working on the left side dash without it.
If you don't I send you a couple of pages from the 71 AIM.
The main difference, I believe, how the harness is routed in 69 compared to 71.
Regards,
Alan
Regards,
Alan
If you are using the original wiring harness, keep in mind that the routing for 1968-early 1970 is different than late 1970-1972.
Your photo shows a very non-stock harness retainer that would locate the harness in the "later" location.
Regards,
Stan Falenski
Regards,
Stan Falenski
TAKE THE STEERING COLUMN OUT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It's easy you are half way there .I am 6'4" 275lbs and trust me it's like trying having S**x with wife your 150 lb Bull Mastiff dog in the bed with you:cheers
Hi b,
I'd think the 69 pages you have are going to be more help than the 71 pages I might send you. (I was thinking perhaps you didn't have anything to refer to.)
Are you looking at both the dash wiring and a/c option pages?
Regards,
Alan
Which sheet can't you read?
Regards,
Alan
I can't read page 300 in my 69 AIM... UPC12/B6. ... shows the backside of the instrument panel bezels along with lights, etc.
Hi b,
No!!!!
I meant pages from the 71 version of the AIM!
Yikes!
Regards,
Alan
No!!!!
Yikes!
Regards,
Alan
