Rivets
Rivets
I'm working on the dash of my '69. I'm finding lots of rivets that I had to remove to repair and refinish some parts. Do most replace the rivets with pop-rivets or go with the original style rivet?
Gus
Gus
Received 2,878 Likes
Hi Gus,
It depends on several things...
Was it a pop-rivet originally?
If it was a soft aluminum rivet, will a pop-rivet work in it's place?
How much like it originally was do you want the finished product to be?
Regards,
Alan
Setting the soft aluminum rivets can be pretty easy in some locations and really difficult in other locations.
Regards,
Alan
DUB (01-05-2016)
Good Luck either way.
ZIO
DUB (01-05-2016)
My .02 cents worth.
If I remove a solid aluminum rivet...I replace it with just that. If I remove a 'pop rivet'...I replace it with that.
Reason being....and this will be all up to you on how you want your car to look when completed....much like 'Alan 71' stated. When I do restorations for people..I MUST put it back like it needs to be in 99.999% of the cases BECAUSE...I do not want anyone who looks at it when it is completed to see that I took a faster route and those FINE details were NOT taken into account. I prefer to challenge myself. That is half the fun of what I get to do every day.
For me....nothing disgusts me more than when I look at the floor pans of a Corvette that is AWESOME and notice that the reinforcement plates for the seats are held in with pop rivets...and NOT the correct grip range either. To me...it just took that car down several notches in the 'ATTENTION TO DETAIL' department. But...that is just me. And I say to myself....."slacker". SO CLOSE....but yet so far away.
And if you take 'rvzio's' recommendation on where to get the solid aluminum rivets...which is SPOT ON...just keep in mind that there are some companies that sell the rivets that are not correct and are made out of REALLY HARD aluminum and seem to be made more for aircraft usage.
DUB
DUB
