door adjar switch
ok, I see on the passenger side it has three wires, that are attached to small clips that go thru the plastic ring and I guess when the switch is depressed it makes the contact with the three wires.
ajar switch
"when the switch is depressed " blue- just the opposite. the door ajar switch and courtesy light switches are "open" when they are depressed with the door closed on them. When the door opens, the internal spring on the little plunger expands and closes the switch, makes contact and completes the circuit (which for these two switches is the ground circuit).
Received 1,469 Likes
Cruise-In II Veteran
Alarm system uses the front door jamb switches.
jar8502 (07-07-2019)
