exhaust pipe question
Old 01-20-2016, 11:31 AM
upnorth
upnorth's Avatar
Default exhaust pipe question
I have a 1976 corvette with headers . when I look up pipes for it the selection is limited under 1976 . The pipes I have on there now won't allow for the tire carrier which I want to put back on plus there shot . When looking what other year corvette's would the pipes be adaptable to the 76 .
Old 01-20-2016, 11:55 AM
Bimmervet
Bimmervet's Avatar
St. Jude Donor '12-'13-'14-'15-'16
I don't know if this is still available, I bought a cross member trans brace for a 72 Corvette. They have dual exhaust ports built into the brace. Later models only had 1. This was an easy bolt on and with that you can use the complete true dual exhaust
Old 01-21-2016, 09:16 PM
cobrachuck
cobrachuck's Avatar
This is what I did stock L48 auto. Runs good now.
From stock manifolds 2 1/4" to the 2 1/2" X pipe to turbo mufflers. Then tuned it
Advanced timing, re curve distributor,
Runs better now very little restriction<br/>
To exhaust pipe question
Quick Reply: exhaust pipe question
