Window adjustment help please.
This happens with both sides. Took everything apart and cleaned. I have been playing with the passenger side for about 4 hours, have read the write ups and watched the videos. The window will not go up all the way. As soon as it hits the weather strip it slows and stops. But if I open the door the window will go all the way up. And then it is sealed when I close the door. The weather stripping is all new.
I don't know if it's the proper way to do it but when I replaced the spring on my regulator a few weeks ago I couldn't get the window to seal where I wanted it so I loosened every bolt for both frt and rear guide channels, and for the horizontal channel also. Then from inside the car I operated the window and adjusted the guides until I got it where I wanted it.
Mine was the same way. What i did was watch the window as it goes up and it mite be binding on the weather striping. You may have to trim it back a bit. Look at the front forward part of the window weather stripping pull it back by hand and work the window up and down wile pulling the stripping back . If the window goes up better where you pulled back the stripping you can see where it is binding and trim a little at a time tip the window goes up properly. Hope this works for you.
Before trimming anything, try spraying the weatherstripping with some silicon spray. I fixed the power windows on another vehicle by doing this and a can should only cost you about $5 at your local parts store. 3M makes it but so do a bunch of other companies.
540 VETTE
Are your weatherstrip retainers in place on the front pillar? Although they are called retainers there purpose is to help push the window to the outside of the weatherstriping to aid in closing. I believe all years but 68 used them. Even with these in place your still going to need weatherstrip lubricant as Les commented.
John
John
try the lube first. You have to see where the window is binding then trim a little at a time till the window goes up with out binding. My car was binding in the front.
540 VETTE
John
John
Yes I have them on the car.
I will try the lube. 3 hours today, getting frustrated. The only reason I am getting crazy with this is I want to sell the car.
It seems like the glass is to far forward. But there is only a small amount to go back before it hits the door.
OK lubed it up with WD 40. went up and down smoother. I think I got it adjusted to were I started yesterday. The glass seems to need to be a little higher in the front and lower in the back. If I twist the glass a little as it goes up it works.
Found out the rear of the glass weather stripping is where it is binding. Will try lubing it and then trim it. How do you trim it so it dosen't look like bubba did it.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
What brand is the weatherstripping? If it's the imported reproduction stuff there are issues with the weatherstrip that include the pillar being an extrusion and they are harder than they should be. This can cause a bind up with the door glass. Some USA stuff has the extruded A pillar weatherstrip too so it can still be an issue.
Willcox
It sounds like you are close.
Willcox
Willcox
I am not sure what brand it is. But the one at the rear of the door glass is the problem. I removed it and everything works fine. It seems to not have any give. What do you recommend.
I looked through your profile trying to find what year this Corvette is????
Because the rear vertical weatherstrips are different from a 1968 to 1982 and that can makes a difference in how the glass will go up with the door shut....due to WHO made the weatherstrip.
And for what it is worth. When I check to see if the door glass is adjusted correctly...I have the engine running. I personally have adjusted a window for so long I was eating up the battery and when I cranked the engine...the window would do what I wanted....just 'saying'.
Not knowing how much you have replaced in this area....I can say from experience that IF the front roller that is attached to the glass and rides in the front track has any in and out play....attempting to keep or get a door glass alignment hold is about impossible.
And this is IF the door glass has play in the front and or rear roller...then this is where the door glass can tilt where you DO NOT want it to tilt and be able to control. So..if the door glass is all the way up and you can move it in and out and the felt adjusters allow to to pull against them and you can see that there is play in the front/rear roller...you are fighting a loosing battle.
Also...if the density of the weatherstrip is dense....because there is some weatherstrip otu there that are WAY too dense and will make the door glass FIGHT like crazy to go up all the way when the door is shut... Then.... what you are trying to do may be futile.
Not knowing what procedure you are using to adjust the door glass...it is hard to comment on that. I have way that seems to work for me...and your method may be the same....that I do not know.
Wanting to help...just do not know how...without more info or talking about what is happening when you raise it when the door is shut and what happens when the door glass is UP and you shut the door.
DUB
DUB
DUB
DUB
Well last night I did a little experiment. I took a long drill bit and drilled out the center of the B pillar weatherstripping. It took away some of the hardness and it worked great.
Former Vendor
Look on the back of the weatherstrip for the small letters .. CRC if they are there then you have the best there is being made at this time. If they are not there, then you can order the door glass rear weatherstrips in pairs without getting a kit and they are not that expensive. I'd need the year to post you a direct link but this one will get you close.
https://willcoxcorvette.com/catalogs...oor+glass+rear
The car is an 80 and there was no lettering on it. Thanks for getting back to me. I want to see how long the weatherstrip holds up now that I have hollowed it out. It is working fine now.
