Headlight questions
Headlight questions
Should all four lights come on when on high beams? I have outer two on with low beams and one inner and one outer on high beams. Owner manual calling for 4000 low beam bulb and 4001H high beam , better more modern choices for 1981?
Both outside ones on low, all four on high.
65GGvert wrote the way it is!
Some people have done a modification to the bulbs to use a halogen bulb inside the bulb if I am not mistaken from what I have seen...but I might be wrong on this.
Installing a halogen bulb is all I would do.
DUB
DUB
Received 1,469 Likes
Cruise-In II Veteran
Have you checked the connectors on the lamps which do not light? Could be in need of a cleaning.
81's came with Halogen high beam bulbs, while the low beams were standard Guide Power Beam sealed beam bulbs.
And in the very early cars with low amp rated alternators...I will generally 'bump it up' in amp rating due to many times there are a lot more things being installed electrically and the factory alternator will not work well....or at least pushing its limits of being effective.
And for those who may not know this....using relays for your headlights will allow you to supply more power to the bulb. Thus...the brighter the bulb will be.....so it has been discussed before here on the forum in detail. I personally have never tested this philosophy with a light meter to verify...but it seems correct in principle.
DUB
Thanks for the info guys. Seemed strange one outer low beam goes out when i switch to high beams, but I haven't pulled the bulbs out to check connections or which bulbs are bad yet. Warmer by the computer than in the garage.
