Willcox Weekend Sale: Carpet, Door Panels, Seat Covers Weatherstrip and More!
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Weekend Sale Starts Now:
This offer expires Sunday at Midnight
Weekend Sale includes a special discount code with a lower minimum on the 10, 15 and 20 off codes.
The 15 off code is for most the entire website
Don't miss out! ! ! Ca map products are exempt.. that's about it.
NEW15is the code. Other exclusions may not be listed.
The 20 off code changes weekly.
You'll have to check the flier below for details.... and CA products are exempt from this code as well. You should use the provided links at the bottom to maximize your savings.
The codes have some restrictions (listed on the code flier) and special links are posted below to get you to the correct area needed for the appropriate discount.
To Receive the special discount you must order from the links below. You can place multiple orders and should if you need seat foam and other interior products. Review the items in the 20 code, they change weekly.
Discounted Corvette Parts are only one click away!
Repair and Installation Help Site:
We've been working on sorting all the info for you by making categories for each page or manual on this site.http://repairs.willcoxcorvette.com/
Seat covers.
Discounted 58-82 covers can be purchased at the links below.
Corvette Leather Seat Covers
Corvette Leather Like Seat Covers
Corvette Mounted Seat Covers
Corvette Vinyl Seat Covers Original
If you need seat foam, it is only eligible for 10 percent off and it would ship separately so please place a second order for the seat foam at this link. Discounted Corvette Seat foam
Corvette Door Panels
Can be found at this link! Select the year when you get to the page. Specify year and color when you check out.
Corvette Dash pads
Other items can be found here:
Corvette Carpet Set
* products are not those of CA. Exclusions include interior packages, bumper cover, exhaust, fiberglass items that ship oversize.
Seat covers.
Corvette Dash pads
Corvette Carpet Set
Former Vendor
ttt
Alright, so I have asked you this before but it was so far back that I can't find it. I have a '68 with an L88 big block in it. The steering column was changed to a later column with the ignition on it. It still has all for taillights like a 68 but is missing the reverse lights under the bumpers. I know I will at least have some rewiring to do, but what do you recommend for the wiring? 68 wiring or a later set?
Former Vendor
Answered you below..
-Willcox
-Willcox
Former Vendor
ttt
Former Vendor
Stay with the 68 harness and you'll have to move the wires for the ignition switch connector. Switch to the 69 main harness and you'll have that portion correct but then you'll run into wiper motor issues due to the forward harness being different. But that might be a blessing. Then you'd just wire it up like a 69 wiper set up.
A simpler change would be two go back with the 68 dash pad and put the ignition switch back on the dash. Then you go with the 68 harness and the only thing you'll have is a non working switch on the column (except for the turn signals which could be wired around if needed. I have the harmonica connector used and you'd need it to complete it this way.
See the dash main is going to have the U shaped connector for the turn signal switch. If you buy the harmonica style, you simply un-pin the wires from the new main and load them into the new connector.
The back up lamps worked off the shifter... so that's not going to play a part in this decision.
The small gauges all plug up the same on both years... and so do the lamps and bulbs for the speedo and tach...
Your call there, just depends on how much work you want to do on it.
Willcox
Former Vendor
ttt
I think it's going to be tricky either way you go...
Willcox
Willcox
Former Vendor
Thanks for the response. I kinda figured I had my work ahead of me either way I go. I have all the wiring still in the car, I just want to replace everything since it is quite aged and part has been destroyed by mice. I noticed there is only one engine harness choice in the 68 harnesses, was there no difference between the harness for the small block and big block that year? I notice other years had an option for both.
Former Vendor
ttt
