M/t finned valve cover BBC
thanks what intake/air cleaner did you use? I'm looking to use a wield stealth or edelbrock rpm or performer type. I'm hoping they clear the hood. i have a holley double pumper i will be using.
Can't help you there. I ran a number of different Holleys on the early Edelbrock Torker in the mid-'70s. Had a hole in the hood with an aluminum scoop through it. I'm sure there are other options now that weren't available back then.
