Control arm bushing failure!
I installed new control arm bushings several years back, but it has taken a while to get the car on the road. Right now those bushings probably have less than 5 miles on them and they are split and falling apart! This was noticed when I took it to the vette shop for an alignment. These were Rubber bushings from Moog (I believe it was, they came in the package with the shafts...blue and white box). Is it possible these were just old stock and rotted to begin with? Or is there another problem I should be looking for that could cause this? Car is a 78 and suspension set-up is stock other than a spreader bar. Shop is going to replace them with poly bushings for me, but I want to make sure we arent missing something else.
Now for poly, do a search here you will find similar problem with poly bushings falling apart in 1-2 years also.
I have poly everywhere, expect a harsher ride. They have been installed for 3 years with no sign of failure or aging.
They are made by energy suspension.
A Few of the "black" polyurethane components contain graphite to add a lubrication property check if the bushing contain this.
If they don't they will start to sweak at some point.
Received 3,218 Likes
To the best of my knowledge, genuine Moog parts come in YELLOW and blue boxes......
If you bought them over the internet, they are probably junk phonies.
That is a bummer to redo..
Nam Labrat
Received 4,153 Likes
Also......just hand tighten the bolts that hold the control arm bushings in place......then lower the wheels onto the concrete/roll the car forward and backward a few feet to let the control arms and tires "settle".......then while the car is on the concrete tighten the bolts to the correct torque (this method prevents the rubber inside the bushings from "twisting to pieces".
MSGT-R (02-16-2016)
Received 3,043 Likes
St. Jude Donor '05
Like rubber but dont trust its origins these days. Curious to see how long the body mounts (rubber) hold up
What a pain....get the polygraphite (black) never had a squeak or anything looking funny
Thanks for the tip! I wish I would have known that back when I put them in! Live and learn
Ill let the shop do it this time around since we have a baby due within the next 2 weeks or so...no time for this type of thing right now. Stink to have done it and have to pay someone to do it again though.
Nam Labrat
and here's an early CONGRATS!!!
Problem is, Moog, as well as way too many American manufacturing companies, is moving more and more of their operations "off shore". I learned this by working part time at Advance Auto Parts, after retiring from full time work.......
Thanks, EPA and OSHA!!!
This is the sort of thing that is common, and should be included in the instructions.. but it's not.
