1975 radiator core and droopy fender
The fender doesn't line up with core support holes. The fender has drooped. Wheres the best place to lift on the fender so I can get the bolt holes to line up. I have a new core support bolts and spacers. The car only sat about a month and half with out the radiator core now its of by a half inch.
If my memory serves me correctly....there are TWO brackets that secure the radiator support to the front impact bar at the bottom. If they are removed...you can install the radiator support and get it bolted in place...and USE the radiator support to raise up the front clip so you can install those two 90 degree brackets.
DUB
DUB
Received 1,468 Likes
Cruise-In II Veteran
DUB
