78 Ignition lock broken Starts with no key
I started the car as usual when I went to turn it off I pushed down on the lever as I always did to remove the key & wouldn't come out.I worked with it for 20 minutes and finally I had to pry the key out with a small screwdriver. Now It will start without a key how much trouble is it to replace the ignition switch?
Has anyone changed a 78 Ignition key lock?
I don't know how that happened the key wouldn't come out now it don't need a key, I guess this hasn't happened to anyone else on a 78.
Unless you turned the lock past off to the lock position, you can remove the key and the ignition will still function. The key can be removed in any position except the final lock position and still operate ignition
You can also lock the ignition by turning it past off without key in ignition and it should lock the switch.
Just discovered this on my 78 last week and it. Kind of freaked me out.
Good luck... GUSTO
dobedave (03-02-2016)
You didn't mention the type of steering column in your 1978 Vette. I will assume that you had a Tilt & Telescoping type since by 1978 most Corvettes had the T&T type column.
Now, one other thing, let's get our terminology correct.
1. The ignition switch is mounted on the steering column jacket, down under the dash. This made General Motors vehicles much harder to "hot wire" since the steering column has to be dropped down from the dash to reach the switch.
2. The ignition lock cylinder is the part where you stick your key. This is most likely the part that needs to be replaced since you mentioned the problem most likely occurred after you had to pry your key out of the lock cylinder. The lock cylinder is connected to the ignition switch by means of a rod that extends down from the steering column head to the switch.
Replacing the lock cylinder can be accomplished without dropping or removing the steering column from the car. You will need to purchase or borrow a couple tools to make the job much easier. They are described in the following papers and pics. They will walk you through the lock cylinder replacement procedure:
http://jimshea.corvettefaq.com/?p=1004
http://jimshea.corvettefaq.com/?p=1009
Jim Shea
Jim Shea
