Fan clutch
Old 03-21-2016, 09:24 PM
rol51
rol51's Avatar
Default Fan clutch
I'm restoring my 1974 and does have AC, can I do away with the original 7 blade fan and fan clutch? And replace with a flex fan and spacer? Or do I have go back with a fan clutch. Please advise.
Old 03-21-2016, 10:14 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
Of course you can, question is, do you really want to?
Old 03-21-2016, 10:17 PM
Jeff_Keryk
Jeff_Keryk's Avatar
The steel fan and thermo clutch is the best way to go. Remember, it free-wheels when not needed.
rol51 (03-22-2016)
Old 03-22-2016, 07:42 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
...I'm restoring my 1974 and does have AC, can I do away with the original 7 blade fan and fan clutch? And replace with a flex fan and spacer?..
You are likely to be making a mistake with the flex fan and are better off with the stock set up.
rol51 (03-22-2016)
Old 03-22-2016, 08:38 AM
resdoggie
Had a 1976 L-82, 4-sp
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
Stock fan blows copious amounts of air. I would keep it,
rol51 (03-22-2016)
Old 03-22-2016, 11:46 AM
COOLTED
COOLTED's Avatar
Flex fans can break.
Old 03-22-2016, 12:45 PM
fishslayer143
fishslayer143's Avatar
Depends on the Flex Fan you chose.. the old cheap aluminum version, NO.. But a more modern Stainless Steel Flex is rated for about 9000 rpm, I don t think you can hurt it. And tho a Clutch fan releases at higher rpm, , there is still 20-40 % drag depending on which you use. Standard, HD or Severe Duty.. I run a SS Flex on my 525 HP Stroker with air and Auto and it gets 112 * here ... never had any overheating issues even in slow summer traffic with A/C blasting. The blades need to be at least 1/2 inside shroud....... BTW.. I use the Flex-A-Lite SS High RPM fan , I just looked , its actually rated at 10,000 rpm... theres no one on this forum with a Corvette that can break it.
rol51 (03-22-2016)
To Fan clutch
Quick Reply: Fan clutch
