WHAA! I can't find the horn on my '82!
Old 05-01-2016, 07:09 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
Default WHAA! I can't find the horn on my '82!
No joke I spent about 2 hours today crawling up, under and around the front end of my '82 looking for the horn(s).
I have consulted the AIM, the service manual and on line. I can't find either the horns or a mounting bracket. I traced the wire harness and can not find a end that will plug into the horn.
Now, the PO did replace the front panel (I see the Ecklers tags) and possibly left the horns off.
Any where I can look again?
Old 05-01-2016, 07:16 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
The horns are bolted to the support braces that are at the ENDS of the metal support beam that is GLUED to the underside of the top hood surround that your headlight actuator supports bolt to.
You can access the horn locations from the wheel wells and remove the black plastic/ rubber shielding that hides the side marker lights.
Look at this thread.
https://www.corvetteforum.com/forums...e-request.html
DUB
billschroeder5842 (05-01-2016)
Old 05-01-2016, 10:22 PM
billschroeder5842
Thanks- I contorted my arm and felt/found them.
It makes no sense-- I'm not sure how you would service those things.
Old 05-02-2016, 08:52 AM
Street Rat
Street Rat's Avatar
It sounds like most C3 repairs.
Old 05-02-2016, 05:19 PM
DUB
DUB's Avatar
Simply by how I mentioned in my past post. They are serviced from the underside. AND not that hard to do...but may take a few fasteners to access.
You can service them from the top side with the hood open..because I have done that also...and that is a PAIN to do....but it still can be done.
DUB
Old 05-03-2016, 08:38 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is the picture I had on that thread... and a diagram that will help you once you find the horns if you are having a problem.
To WHAA! I can't find the horn on my '82!
Quick Reply: WHAA! I can't find the horn on my '82!
