Questions on replacing oil pan and gasket
Old 06-13-2016, 04:32 PM
kaz1961
kaz1961's Avatar
Default Questions on replacing oil pan and gasket
My 80 has a crate 350 in it with an aftermarket chrome oil pan which is leaking. I would like to replace the pan and gasket. From doing a search it looks like the one piece Felpro gasket is the one to go with. What would be a good standard oil pan to use?
Old 06-13-2016, 04:58 PM
sullyman56
sullyman56's Avatar
The one piece gasket is the way to go. Just buy a genuine GM oil pan.
Old 06-13-2016, 10:20 PM
bj1k
bj1k's Avatar
There might not be anything wrong with your oil pan . Someone might have just overtightened a cork gasket and crushed it . Remove it to see if that is the problem and replace the gasket with the one piece Felpro gasket . Use a good silicone sealer and don't over tighten the bolts . Tighten them a little at a time using a cross pattern .
To Questions on replacing oil pan and gasket
Quick Reply: Questions on replacing oil pan and gasket
