'69 Fender Louver Trim Finish?
Has anyone re-finished the "satin" looking silver finish inside of the louver trims on a '69? Looking to buy a used set, but they need some TLC and I'm not sure if it's a DIY project or if they will have to be professionally re-finished.
Received 1,468 Likes
Cruise-In II Veteran
The painted areas may have been Argent Silver, same color as rally wheels.
I wasn't aware that those optional louvers had any paint on them. I though the inner areas were just rough cast, then whole part was plated.
Received 2,878 Likes
Hi,
I believe the original TJ2 louver trim was chrome with a painted surface in the recess. Just outer edge of the chrome plating was exposed.
Regards,
Alan
Notice this is the blocked off 4th louver.
Regards,
Alan
Mine were not that bad. when I bought my car 4 years ago I noticed some grease on them, when I tried to wipe it off I realized it was actually black primer the silver paint was starting to chip off a little. I just wiped them down, masked off the edges and a couple of light coats of paint.
Cajun_LS3 (06-29-2016)
[QUOTE=steffan;1592524533]Mine were not that bad. when I bought my car 4 years ago I noticed some grease on them, when I tried to wipe it off I realized it was actually black primer the silver paint was starting to chip off a little. I just wiped them down, masked off the edges and a couple of light coats of paint.
Nice work! Thanks for sharing.
