Need Some Help Re: steering and brake/clutch assembly on a '69
I'm new to the c3 world and test drove my first yesterday, a red '69 coupe. Nice car, body, paint and interior all appear to be in great shape. It is a manual steering car and I would want to convert that to power steering and, possibly, rack and pinion. One thing that disturbed me was the proximity of the gas and brake pedals. I literally could not put my foot on the gas without hitting the brake pedal unless I turned my foot sideways (I was wearing athletic shoes). I can't imagine that is how these cars came from the factory. The guy said that it had a Borg-Warner transmission and, since these cars came with Muncies, I'm wondering if this car was originally and automatic and when it was converted to a 4-speed, the brake/clutch pedal assembly was installed too close to the gas pedal. To any of you experts out there, does that sound like a possibility and, if so, would that be difficult to correct? Also, to anyone who has installed power steering and/or a rack & pinion set-up, is that too difficult for a weekend mechanic?
Received 2,878 Likes
Hi r,
Here's the typical clutch/brake/accelerator configuration and spacing for a 4-speed car.
How does it compare to what you saw?
Regards,
Alan
Regards,
Alan
Hard for me to compare the two by looking. I just couldn't believe that the spacing was such that I couldn't even put my foot flat on the accelerator without hitting the brake.
Take and post some pics of what you have -that will help. Take pics of your pedal assembly and your transmission. I have just added power steering to my '68 Coupe sbc and I am by no means a professional mechanic. Very doable job. There are photos on my thread of GiddyUp Go Daddy's Vette. Will be putting on last piece tonight. You may want to consider the Borgenson upgrade, it looks very good and simple. Very popular here on the forum and done by guys like yourself. I did the factory change-over simply because that was in my basket of parts. Welcome aboard - lots of good information here and guys with lots of knowledge that are willing to help. But to make good recommendations they will need more info (sbc, bbc, etc) and pics. Don't be afraid to jump in and good luck!
original 4 speed cars had a welded in trans crossmember, automatic cars had a bolt in crossmember, clutch & brake pedals only go in one way.
ronj024 (07-06-2016)
on my 66 stick and 72 stick I would drive barefoot/sock foot, I have big wide feet size 11 and like big clunky boots and they anyways hits something down there.....even on rare times I would wear old converse tennis shoes they would hit stuff two pedals etc.
But I normally drive barefoot/sock foot I like the "feel" better.
^^^ is your answer. Most athletic/tennis/sneaker/running/etc. shoes today are a lot wider on the outside than the shoes anyone wore 50 years ago.
Having had my car for nearly 40 years, and my shoe size not changing, I know that once they didn't hit and today they do, thanks only to the difference in the type of shoe.
And yes, it is that tight.
