Broke college student '77 build thread
rgwoehr (07-14-2016)
I went to harbor freight this morning and picked up a DA sander and some sanding discs
I think I stripped more surface area in the past half hour with that than I did in 2 hours yesterday with the other sander. It works fast enough that I decided there was no reason to work in direct sunlight today. I'll wait until this afternoon when I have some shade and should have the rear clip and doors done by the end of the day (except for the areas that I'll have to sand by hand).
Pegan2261 (10-24-2021)
Thanks. They're not my favorite wheels, but I plan to clean them up a bit after I paint the car. I think they'll look much better polished. Eventually I want to get some 18" torque thrust style wheels, but that's not very high up on my to-do list.
Back in the 1970s people paid good money to have designs like this painted on their cars. Far out, man! LOL.
As far as the wheels, they sort of remind me of Trans Am snowflakes. If I ever replace mine, I am leaning toward the Weld S71B rims.
Again, great work and progress, and keep those updates coming.
C3 of Year Winner (appearance mods) 2019
Man, you have been busy! Looks good.
It looks like the interior is pretty complete. You would be amazed how fast those pieces add up if you have to replace them.
Subscribed! Keep up the good work.
Received 1,753 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Based on the areas that you have sanded already it looks like you know, but be sure to keep those fast sanders away from edges. You can grind down some peaks in no time! Looking good!
I think I've seen those rims on a couple cars around here, they look pretty good.
Quick update:
I got a good amount of the driver's side stripped today. I worked on the passenger side rear fender a bit too, so the majority of the rear clip is done. I'm trying not to go all the way down to the SMC with the 80 grit sandpaper because I'm afraid I'll take off too much material as I move on with finer paper. I'm sure the next couple grades will take care of what's left of the paint.
I probably should have closed the garage door while sanding
Thanks! I'm trying my best to avoid ruining any of the body lines. I turn the speed down a bit and use light pressure and slowly take the paint off right near the edges. The reason I initially tried to strip it down with the razor blade was because I was afraid of screwing something up with the sander, but it isn't as hard as I thought.
C3 of Year Finalist (track prepared) 2019
Sounds like you did all the expensive stuff that I still need to do haha. I wish I had an extra $800 or so laying around when I replaced the tires, I would have replaced the wheels too. I considered doing a cheap roller paint job with gloss black a few months ago but decided not to go that route because the prep work involved was the same as what I'm doing now, and as much as I like black on these cars, it isn't what I wanted. I found a SCG '77 for sale and have been staring at photos of that car to remind myself that all that sanding will be worth the effort. http://veh-markets.com/cars/chevrole...ties-gray.html
I might have a thing for black... But steel cities grey is a great colour too.
My car badly needs paint too, it presents a lot better in pictures than in real life! I wouldn't bother with the roller jobs - I've tried a couple, and honestly I think it's a LOT quicker and easier to get a decent result using a gun. I've painted several cars and a horse float using fundamentally the Rustoleum roller method, but spraying the thinned paint with a cheap gun, and you can get some pretty impressive results for the time and money put in. That's what's on my f250, and it's held up pretty well for the past 5 years since i painted it, daily driven over dirt roads, though I need to do some more bodywork before too long.
Looks like the truck came out good. Are you gonna paint the vette yourself?
#33
At least you didn't have 15 paintjobs to remove! As far as thosw wheels, at first I thought they were T/A wheels too. Hang on to them, they may be valuable. There's a guy who buys, restores, and sells vintage wheels, I think I saw mention of him here, maybe someone will chime in.
#34
Also, did you have any problems since replacing the rotors? Did you indicate them in or shim for runout?
P.S. How is the paint on the dash holding up? Details?
#35
Yeah it could have been worse than it is. Based on how many layers were on the hood, I expected the rest of the car to be just as bad, but the rest of the car didn't have that many layers. From what I found on ebay, I might be able to get $400-$600 for those rims. No issues since changing the rotors, and no I didn't indicate them. I forgot I was supposed to do that.
The paint on the dash seems to be holding up fine. I scrubbed it down with dish soap and a tooth brush before spraying it. I didn't give it very long to cure, so I did screw it up a bit reinstalling it, but I've had the dash pad out since then and it seems to be more durable now that it's cured.
#36
Nam Labrat
Received 4,174 Likes
Expert members can correct me if I'm wrong
rgwoehr (07-15-2016)
#37
Progress was a bit slower today for some reason. I sanded the headlight doors and the area around them, and most of the passenger side door. That took about 3 hours, which is weird because I did most of the drivers side and the passenger rear fender in a shorter amount of time yesterday. Hopefully tomorrow I'll be done with the 80 grit.
#38
TheCorvetteBen
This is a great thread! There is nothing like your first C3! I too bought my first when I was 18. Now, ten years later, I have owned more than 30 of these cars. Be careful it can get addicting!
#39
Thanks Ben! That's a lot of vettes. Is that just C3's, or does that include the C4s? I love vettes but I don't know that I'll ever buy another one, there are so many other cars I'd like to own. But who knows, I could change my mind someday. I've thought about replacing my daily driver with a C4 off and on for a while now.
#40
TheCorvetteBen
