Wilwood 260-8556
Wilwood 260-8556
Anyone using a Wilwood brake master cylinder with the hole drilled in the wall between the front and rear fluid reservoirs?
I bought the 260-8556:
https://www.summitracing.com/int/par...8556/overview/
I would think that the level in the front reservoir would get too low because of the steep angle the master is mounted at (brake fluid can transfer from the front to the rear reservoir through the hole)?
Anyone do something (like welding the hole shut) or do you just run it like it is?
/Karsten
/Karsten
Yes, they call it a "feature" that fluid can transfer between the two reservoirs.
It doesn't really matter why it's there, the question is if the Corvette master is tilted too far for this to work without modification (not enough fluid in the front reservoir without flooding the rear reservoir).
Danish Shark (09-23-2016)
I wonder if the hole was always there on that model?
You didn't notice that the fluid level is higher in the rear?
/Karsten
