power antenna for '78 with AM/FM/CB radio?
I am attempting to assist a friend who has a '78 Pace car that is equipped with the UP6 option code AM/FM/CB radio..
He has all the components EXCEPT the original power antenna ..which has some sort of booster for the CB radio...
Looking at my A.I.M. the only part #s I see referenced are: 5044887 and 5044911.
I believe the power antennas used for the '78 VETTES are different from those used prior to or after 1978..
Does anyone have the correct GM OR Delco pn for the power antenna that is specifically for the am/fm/cb radio in 1978?
OR an original power antenna working or not..which might be repaired?
He's almost got his '78 Pace car back to NCRS standards..so it's hopeful he can come up with the correct antenna..
I also wonder IF GM used the same pwr antenna for other vehicles equipped with the am/fm/CB radio in 1978...The mounting under fender might be different..but he has the original mounting-ground etc..still on the car.
He will certainly pay for one that's original..even if it may need some refurbishment..
Please let me know your thoughts, Jim
VetteBob78_L82 (09-19-2017)
Correct part no for 78 and early 79 Corvette am/fm/cb/power antenna is 5044887.
But it's not like that number will do you much good as these are no longer available through conventional sources.
ALL GM vehicles from 76-early 79 used this style antenna, but with different part numbers. And different upper brackets spot welded to the mast tube. And replacement parts carried still different numbers.
You could put together a replacement years ago with over the counter parts with still different numbers, including numbers also on the mast tube.
And the replacement mast tubes were a little different from original equipment tubes as they had various mount holes in them for the variety of different brackets. They also had a noticeable flat spot on the tube.
(NONE OF THESE ARE STILL AVAILABLE)
In my pic, the top unit is a CORRECT Corvette am/fm unit with the upper bracket spot welded in place.
The middle unit is a Cadillac unit. You notice the co/ax connector is located differently and that I replaced the upper bracket with one that I make myself.
Bottom am/fm/cb unit was assembled from nos parts, co/ax connectors in the correct place, my upper bracket installed.
If you look close you might notice extra mount holes.
These turn up on ebay occasionally. I'm always looking. CB units are pretty scarce, tho.
Good luck!
(sent you a PM)
Good luck!
(sent you a PM)
jim in oregon (09-24-2016)
Good luck!
(sent you a PM)
Good luck!
(sent you a PM)
In case you didn't know, that round plastic piece on the mast at the bottom of the pic says it is for CB's. There was the mast, that plastic piece, then about 9-10 inches of top mast. Turning that was some adjustment for the CB reception, I believe.
jim in oregon (09-25-2016)
Thank you ALL for the input..!...Pretty wild all the varying part nos used to accomplish the same job over the years..the NCRS judges must have a tough job determining which items are original and which may have been done as GM repairs..Jim
I really don't think a judge would even be able to see the foil label with the date/part no on it, but not sure.
BUT, there are other things they might notice.
ORIGINAL antennas have a setscrew/lock nut on the bottom to adjust tension on the armature and a ROUND mast tube with the upper bracket spot welded to it.
Replacements may have a yellowish plastic plug in place of the setscrew and a mast tube with a flat side to it, a kinda a crushed area, and various small mount holes, and a screwed on upper bracket.
And some have a black cover on the motor.
And as for original part numbers, my parts book(antenna specific) must show a hundred different numbers.
Each GM model car had it's own number, sometimes changing by year.
The chassis judge may be in a position to view the antenna body, wiring but it is not judged. It simply tells the chassis judge if the antenna body is original or not...more like an awareness item but not judged.
This is true for both NCRS and Bloomington Gold judging. Labels are not judged for either.
Hope this helps!
I have an early 79 which I suspect pulled the Ariel from a 78 parts bin
http://s1308.photobucket.com/user/tzxvp1/story
KapsSA really helped me out as I was missing the top bracket and had to fabricate one.
jim in oregon (09-26-2016)
You'll notice the various holes in the mast tube, not yellow but beige plug in the lower right in the pic instead of setscrew, and 220 prefix part no.
Service replacement, which is why it had no upper bracket installed.
Surprisingly it does carry a 79 date.
I found a replacement AM/FM/CB/cassette for my '81 many years ago in a wrecking yard that specialized in Cadillacs. They even had a makeshift bench set up to test the one you wanted. Remember there are external boxes that go with the radio so make sure you get all the "trimmings".
LenWoodruff (09-07-2018)
Part
I have one ...1-805-310-1284. ...Pete....👍
I also have one. Bench tested went up but wont come down. will need repair but is the original. I will take offers just PM me please
1978 GM CB Power Antenna
Spoiler
Same issue
My new to me 78 pace car has the CB, the Antenna doesn't work. Makes noise but does not move.. My unit looks like yours except for the two coax cables are opposite each other on my mast. Does that matter? I am completely new to all of this. I have the unit out on my kitchen table as we speak. It may be easier for me to find a newer working unit by the sounds of things. Any advice will help. Wondering if Ii could use the drive unit off another rig and put my am/fm/cb column on it? I also have no idea how to install the new cable. If anyone knows how, please tell me.
Sounds like motor is still good just needs the plastic cable that works the mast.
Search for Kaps antenna repair he will fix the one you have. Take a picture and put it up here.
LenWoodruff (01-31-2022)
