vacuumn diagram for 1972
Old 10-22-2016, 12:35 PM
540 vette
540 vette's Avatar
Default vacuumn diagram for 1972
Anyone have a vacuum diagram for a 72.
Old 10-22-2016, 12:41 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi 540,
Vacuum diagram for the engine or for the wiper/headlight systems?
Regards,
Alan
Old 10-22-2016, 01:59 PM
540 vette
540 vette's Avatar
Originally Posted by Alan 71
Hi 540,
Regards,
Alan
Headlights. Thanks Alan.
Old 10-22-2016, 03:23 PM
Alan 71
Alan 71's Avatar
Hi 540,
The Willcox site has good vacuum SCHEMATICS in their "how to do" section on their site.
Personally I wouldn't work on the headlight/wiper door system without the relevant pages from the AIM and the Trouble Shooting Guide from Dr.Rebuild in front of me.
Regards,
Alan
Old 10-22-2016, 06:49 PM
540 vette
540 vette's Avatar
Hi 540,
Regards,
Alan
Nothing wrong with the system, everything works great. Just have to disconnect everything to detail the engine compartment while the motor and front suspension are out. I will be removing all the wiring and vacuum lines. The guy before me painted everything black. I don't know if I am going to clean all the hoses or get new ones.
Old 10-22-2016, 07:35 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Willcox
Old 10-22-2016, 09:01 PM
540 vette
540 vette's Avatar
Originally Posted by Willcox Corvette
Willcox
Perfect. Thanks.
Old 10-22-2016, 09:48 PM
0Willcox Corvette
Former Vendor
You're most welcome.. Willcox
Old 10-23-2016, 12:54 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
When removing/replacing electrical wiring or vacuum lines, wrap a piece of blue painter's tape around each wire/line end with a letter or number code and also put a like piece on the mating part. NOT doing this can become a disaster.
You can also easily restore wiring and hoses that have been painted black by using a cloth dampened with lacquer thinner to wipe them down well. Use chemical-proof gloves and do this in a fresh-air environment with a fan blowing away from you.
When done cleaning this stuff, wipe on a coating or two of Nu-Vinyl polymer protectant (or Meguiar's protectant for plastics) and the wires and hoses will again look brand-new.
This is one of the best clean-up tasks you can do for your engine compartment.
Old 10-23-2016, 01:41 PM
Alan 71
Alan 71's Avatar
Hi 540,
Saving the original hoses, if possible, is a good idea because some folks feel that the old hoses are superior to the reproductions being sold.
Some people recommend cutting about 1/3" off the end of each hose. This gives the hose a fresh sealing area where the hose is attached to the switch, relay, or actuator. Cutting them that much almost always leaves them with more than enough length.
I agree that cleaning the hoses is quite possible.
It's a good idea though to try to find a solvent that will remove what's presently on the hoses but leaves the original colored stripes in place. The striped hoses make it a bit easier to get the hoses back in the proper place.
Good Luck!
Regards,
Alan
Old 10-24-2016, 10:06 AM
540 vette
540 vette's Avatar
Some good tips guys thanks.
To vacuumn diagram for 1972
Quick Reply: vacuumn diagram for 1972
