I put some blankets and cushions on the roof of the Vette and placed it there... Easy, convenient. Probably wouldn't have gone that way if I had a really nice paint job though.
It doesn't matter how you store it, but it takes up less room if you stand it up. BUT...put padding under it so it will not be supported just by the nose. I think you might be better laying it on a side so the load can be spread; and probably with the underside facing out (less chance of damage to the paint). LOTS of protective padding, for sure.
I put a couple of lag bolts in the wall studs at an angle so that it slides toward the wall, and hung the door by the hood latches on them.
Drape a blanket over it if it's in an area that sees traffic.
Wire the latches to the bolts if it's a wall that a door is on so it is not jarred loose by the door closing repeatedly.
