72 Alarm Issue
72 Alarm Issue
A great diagram ... I have a 72 and have recently purchased a rebuilt "D" alarm lock and had it keyed to my glove box lock that's from the factory. I've had the car a few months and somewhere along in it's life someone put a door lock in the place of the alarm and cut the orange and pink wires and left them hang. Upon me putting the correct alarm lock in and splicing the wires to attach ... the orange wire inadvertently touched metal and sparks flew (shorted out). I thought it was the 20a fuse marked clock/lighter/courtesy but that fuse is good. Did I short out the relay in the jack storage area? Or the flasher? I have no power now to the orange wire which I obviously had before the sparks. I also presume the orange wire goes to the lock connection with the tab on it and the pink to the other. That's how I currently have it wired and installed. Any help would be appreciated. Thanks!!
did you test both ends of the fuse with a volt meter or test light?
gmfn86 (12-05-2016)
To answer no ... but I actually replaced the fuse and nothing different. I never lost my clock/lighter/courtesy lights either. Everything else seems to be working too. I looked at the other fuses and they all look good also. To make this job even harder I noticed I don't have the pin switches either. Seems they were lost on the cars' way to me. Do they just screw into the opening like the courtesy light switches do? Can I access the wires from both back wheel well access doors? I want to put this car back the way it was from the factory ... alarm included. It's getting there but little things seem to be slowing me down. The pin switch under the hood is there and I have ordered a new latching relay and flasher, so I know they're new. The alarm horn is there also. Looks like from 1972 though. I'll check that last.
Any help on how the pin switches install? Shorting out the orange wire most likely didn't damage the relay or flasher in the rear compartment? Thanks.
Yes, they do. Turn signal & emergency both work. I'm stumped as to the fuse I blew and now no power to the alarm. I'm going to check in the door in the left rear wheel well to see if the orange wire is fused somewhere along the line. I have to have access to the alarm pins that way to replace them. Hopefully those wires are there also.
Received 1,244 Likes
The door switches only bring a ground to the relay, I don't guess that anyone would put a fuse in there but you never know!
Yes, the factory alarm (orange wire) is protected by the courtesy fuse but if everything else on that fuse works then it makes no sense.
When you had the initial short was it one spark or did it melt first?
I have the utmost confidence that you will figure out the problem.
Touching a bare wire to metal is a bad idea.
Use a meter and attach the BLACK lead to a ground and test the wire with the RED lead and see if you have 12 volts that way.
gmfn86 (12-07-2016)
Yes, I agree on the touching metal part. Should have disconnected the battery before splicing. Hindsight here. I'll try to see the volts I have. I've now installed the alarm lock and it's hard to reach in there through the license plate light but I'll do it ... I have to. I'll let you know. Thanks for responding here.
Alright, checked the voltage and have 12.8 on the orange wire (never did blow the fuse after all) but after purchasing a rebuilt "D" alarm lock on ebay ... I don't even have 1 volt on the pink side when lock is in the engaged position (90 degrees right). I had the lock re-keyed to my glove box lock and the locksmith mentioned to me that 2 of the 6 tumblers were missing. He fixed it. I contacted the seller about the tumblers and he mentioned that he doesn't rebuild them. WTF. Now I have to contact him for my money back. The price wasn't cheap either.
Good news and Bad news!
Good:
That the orange wire didn't blow the fuse and it has 12 volts on it.
Bad;
That the switch is not working properly.
You might try to soak the switch for 20 minutes in a solution of
two parts ammonia and
one part peroxide.
Then rinse it off with water and use compressed air to blow it clean.
If after two tries if it doesn't work then it's shot.
Bad;
one part peroxide.
gmfn86 (12-08-2016)
Good:
Bad;
one part peroxide.
Bad;
one part peroxide.
Pin Switch
A new issue with the alarm ... I already realized I didn't have the pin switches but upon opening the wheel well door ... I had no wires either. I took parts of the interior out to search and found the white and black wires that go to the pin switch but also found a light blue wire. They were all wrapped together with electrical tape by a previous owner. What does the blue wire go to? Looking at the schematics, I can see the white and black on the pin switch ... but it also looks like another wire is there too.
I'll take a wild guess!
Is the blue wire the ground for the 'Door Ajar' light?
https://docs.google.com/viewer?a=v&p...GE5N2EzZGI2Mjc
gmfn86 (12-08-2016)
Good:
Bad;
one part peroxide.
Bad;
one part peroxide.
I still don't know if it'll completely work but it surely is much closer than before. This cleaning solution was the answer to a lock that was dirty and corroded. Maybe just corroded ... that was most likely the particles that were left in the cup. Thanks!!
The switch should be 100% OFF straight up and on at 90*, that switch is bad.
How did I know that the seller would say'The key lock was good until you broke it'! LOL!
You can buy a good one from one of the vendors.
Order the wire terminal ends along with the door switch's as they are special.
gmfn86 (12-10-2016)
Can this lock be repaired/rebuilt ... or is it past that point?
Is there a vendor here that you would suggest for a new one? I wanted the "D" Alarm lock because it was the proper lock from the factory for 72. It was the only one for sale on ebay. They're hard to find. I know there are universal ones out there though.
Oh, and yes, I ordered the wire ends too. 12 to be exact.
