tilt/telescope
tilt/telescope
I'm sure it's been asked but was there an option of tilt or telescope for the 68. Mine has neither Thanks Phil
Thanks for quick response. Phil
Phil, I started some research on this subject because I am quite tall and was looking for a shorter SC to give me more leg room, but I never reached a conclusion on it.
Nonetheless there is info in the attached thread you might find useful...
https://www.corvetteforum.com/forums...ng-column.html
Thank you I am leaning towards an IDIDIT column Phil
Other possibilities are:
1. replacing the 16" diameter steering wheel with a 13-1/2" wheel of similar design;
2. removing seat and then removing seat rails/modifying seat mount plates to drop seat another inch or so and positioning seat rearward to bulkhead (leave enough clearance to tip seat back forward when needed);
3. modifying stops for seat back so that you lean back more and have more clearance to steering wheel.
this is perfect timing for this thread.
I'm 6'4" and the only way I can seem to fit in my 68 is to pull the telescoping steering wheel all the way out toward the driver. any closer and my right let does not fit between the when and seat.
Does anyone have a source for a smaller steering wheel that still looks like the original wheel
I agree with tiger joe ,does anyone have a smaller one ,I checked with the corvette vendors ,and they all have one that is one inch smaller ,but it doesnt look like the original,it sucks!
I have a personal question if you were 6 foot and 200 pounds how would the stock telescoping column fit you? The reason I ask I have a stock telescoping column that I may sell and get a Flaming River tilt stock replacement. The car that I reasonlly purchased had the column in it but no seats or dash to check the fit.
I'm 6'4" and 215. for me the only issue with fitting is steering wheel hitting my leg.
Seat all the way toward the rear, and I extended the telescopic all the way out and I fit no issue, my leg clears the wheel I just have to sorta slide it under the wheel to get in. for me I think a smaller wheel would help out a lot
Just get a smaller steering wheel. Going from 16" to 14" (or less) will make a big difference. Of the tilt/tele options, "tilt" would be best as it actually adds clearance when tilted UP.
Received 1,469 Likes
Cruise-In II Veteran
