Pilot bushing giving me a hard time.
Put one in my 502 last night and then put the bell housing and clutch assembly together. Tried the trans and it wouldn't slide into the bushing. Took it out and bought another one. Put it in the freezer and then installed it, tried the trans again. Won't slide in. Read everything I could find. Any ideas.
Dr. Detroit
Received 3,891 Likes
See if somebody has a cutoff input shaft you can borrow to center it up if you are not already using one.....the clutch tool that comes in most kits is garbage......
Jebby
The problem is when I try to put the shaft in without anything on the flywheel. It still won't go in. I am going to clean it up inside with a grinding stone and see what happens. I saw it in a thread on here when I was searching. Thanks.
Have you tried the bushing on the input shaft to check the fit before you installed it ? Perhaps a bellhousing alignment issue ?
Dr. Detroit
Maybe the input is slightly mushroomed....I agree, stone it.
Jebby
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Go to the crank shaft pulley bolt with a strong arm and turn the engine slightly... It sounds to me as if you have a splining issue and that might cure it.
I'll try that. What do you mean by splining issue.With the engine on the dolly it went in when I jiggled it. You know when I do it under the car it will be a pain in the butt. Thanks.
Also, I think Willcox is assuming that you have the clutch on the flywheel as well. Spline issue he is referring to is the clutch disc to input shaft splines (I believe.)
So Flywheel on the engine and NO clutch assembly, jiggling the trans will allow you to slide the trans in flush to the bellhousing or is the bellhousing installed on the transmission and then trying to install the trans/bellhousing assembly onto the back of the engine ?
I set up the clutch with the trans. The trans wouldn't go in just the flywheel.
When I set up the clutch I used the trans instead of the aligning tool they give you. I had the engine on a dolly. At that time I had cleaned up the inside of the pilot bushing so the trans now slide in.
The trans wouldn't go in just the flywheel, I meant it wouldn't slide into the pilot bushing. Sorry for any confusion.
Could the bearing retainer be hanging up in the bellhousing flange? Sometimes having someone press the clutch pedal while you push it in that last little bit will work, if it is indeed a spline issue.
The bearing retainer was also a problem. I had to clean that up to get it to fit. All new parts nothing fit right.
The pilot bushing has a beveled edge that faces the transmission. Is it installed correctly?
Make sure the clutch disc moves easily over the transmission input shaft before you continue.
Use a clutch tool with splines to set the clutch disc. Before you tighten the pressure plate bolts, and the clutch plate will move with the clutch tool, notice that the clutch tool has some play. That is to say that you can move the clutch tool somewhat due to the slop involved.
Move the clutch tool so that the disc is centered on the tool and the same amount of slop exists at 12, 3, 6 and 9 o'clock positions. Tighten the pressure plate and make sure the tool will go in and out of the disc with very minimal friction. Put a small dab of grease on the inside of the pilot bushing, excess grease will cause a hydro lock and prevent the pilot shaft from entering the bushing.
Use a large floor jack (try to avoid one of those chinsy "trolley jacks") or transmission jack to install the transmission. Set it up so that the transmission is supported, at a similar angle as the engine, most importantly, make sure that the transmission moves easily on the jack,allowing up, down, left and right movement as you insert the transmission.
Should go easy easy as pie...
Received 1,116 Likes
How are you supporting the transmission? My strategy and others around here is to cut the head off of four long bolts and screw them into the bellhousing. This provides a nice guide path. Not perfect but close. You only want a bolt with a short length of thread and the rest smooth. Also I cut a slot in the end so I can get them out with a screwdriver. A bit of setup work but definitely makes the job go more smoothly. If you want more info about what size bolts, I can head out to the garage and see what I have.
