Big block water pump 3 groove pulley. For cheap.
Old 01-29-2017, 03:16 PM
540 vette
540 vette's Avatar
Default Big block water pump 3 groove pulley. For cheap.
I needed one for my 72 with a 502. When I saw the price they were at $215 and more I decided to find a used one. One came up on E Bay for $95 and I scooped it up. Thinking I had a good deal there.
When I cleaned the paint off of it the part number I found was 90840. I looked it up and found out it was from a Mercruiser boat engine.
It fit perfectly on my big block, the belt lined up. You wouldn't be able to tell the difference if you sat one next to the other. I can post a picture if needed.
The best part is I over paid for mine at $95. Maybe because he advertised it as a BB Corvette one. They sell on there for between $50 and $75.
I don't know if anyone else found this, I did a search and nothing came up. I hope it helps guys doing a BB swap.
The following 6 users liked this post by 540 vette:
20mercury (01-29-2017), 69427 (01-29-2017), carriljc (03-13-2021), Greg (01-06-2022), leigh1322 (03-09-2021), platinummaker (03-17-2021) and 1 others liked this post. (Show less...)
Old 01-30-2017, 12:53 AM
20mercury
20mercury's Avatar
Default Dang and good to know.
Dang and this is good to know. Wish I had known this 6 months ago when I bought the 3 groove pulley for $200. Looked all over and finally bit the bullet, sucked it up and paid the price as I had to have one. I wonder how much stuff out there is just like this. Thanks for the info.
Old 01-30-2017, 06:18 AM
540 vette
540 vette's Avatar
I wonder what the brackets look like.
Old 02-09-2017, 11:33 AM
540 vette
540 vette's Avatar
Here are a couple of pictures of the installed pulley. Everything lines up like it was made for a Corvette.
The following 2 users liked this post by 540 vette:
centuryoldracer (05-19-2017), interpon (03-09-2021)
Old 02-09-2017, 12:10 PM
Tim 1973
Tim 1973's Avatar
I might have the org BB pulley's from my 73. I'm putting a LS motor in my Restro Mod. I'm headed back to Texas Tomorrow and will look and post the number that's stamped on it.
Tim
Old 05-19-2017, 01:59 AM
centuryoldracer
centuryoldracer's Avatar
Thanks for the tip, I just ordered one for my BB car.
Old 05-19-2017, 08:21 AM
John 65
John 65's Avatar
I remember seeing this thread months ago and just passed it along to another member yesterday who was looking for the 3 groove vette pulley. Saved him some $$$. Thanks for the tip.
Old 05-21-2017, 04:33 PM
540 vette
540 vette's Avatar
Glad to help guys. Thats what the forum is for.
Old 02-15-2021, 02:32 AM
540 vette
540 vette's Avatar
A good thread to revive. People doing a big block swap and needing the 3 groove water pump pulley that is expensive. This is a cheaper alternative and it works.
John 65 (02-15-2021)
Old 02-15-2021, 03:26 AM
derekderek
derekderek's Avatar
Received 3,388 Likes on 2,633 Posts
there is a small block version too.
Old 02-15-2021, 07:38 AM
John 65
John 65's Avatar
Thanks for bringing this one back Steve.
Old 03-09-2021, 09:22 AM
Hdmike444
Hdmike444's Avatar
Hi
what belt are you running on the alternator? And I will be looking into this pulley thx
Old 03-13-2021, 09:48 AM
540 vette
540 vette's Avatar
Originally Posted by Hdmike444
Hi
Stock belt
Old 03-13-2021, 09:54 AM
Hdmike444
Hdmike444's Avatar
Any idea what number it is
it looks a lot wider than mine
Old 03-16-2021, 12:05 PM
540 vette
540 vette's Avatar
Sorry I don't have the number.
Old 01-06-2022, 06:28 AM
540 vette
540 vette's Avatar
Anyone doing a big block conversion this will save you money.
Old 01-06-2022, 08:44 AM
pro-amature
pro-amature's Avatar
FYI, the early 70 and older BB 3 groove used a smaller water pump hub bolt pattern making the use of the original water pump and fan clutch impossible, unless of course you drill the pulley for the smaller pattern. The BB water pump rebuild kits include, apparently, a multi bolt pattern hub though, but there still is the fan clutch problem. Got my kit from CC. Had to fix this cobbled mess last summer, welded the holes up and drilled new to save $.
To Big block water pump 3 groove pulley. For cheap.
Quick Reply: Big block water pump 3 groove pulley. For cheap.
