I would say so. I would remind you that simply because it says OEM doesn't mean that it will fit. This means those four corner "EARS" on the gas tank. I replaced mine, also an '82. job is not impossible I was forced to use a floor jack with a bottle jack on top. I used this setup to press the replacement tank because of a very tight fit. Don't forget to install the fuel level sending unit/fuel pump before you install the tank. Makes it much easier, ask me because I forgot to.
