Name that part!
Name that part!
When we purchased our C3, it came with a couple of extra doors and a box of parts. Some I can identify, some not so much. Would you please help me identify?
I know the high beams switch, but what are the 2 items to the right?
Received 1,469 Likes
Cruise-In II Veteran
Folding top rear bow pin housing and pins; choke coil and cover; a set of points; rear bow lock for the underside of the deck lid.
The AIM shows everything but the point set.
c1nicole (02-28-2017)
Floor dimmer switch, driveshaft universal u bolts, thermostatic choke spring, the little ball stud thing (I don't think) is a Vette part. It's for a hatch strut mount. Convertible top pin latch male and female, rear. Vaccum T aftermarket.
about half that stuff is junk. tire weight, rusty bolts, broken window winder (must be a Ford part!) lol
Cmon...how about something difficult! Cheers. unckahal
Radiator support with radiator cross-member. Front header bar (goes in front of the headlight openings along with the rear headlight support (don't know the official name for it). AC compressor. A couple of steering boxes. I see a water pump. A brake rotor (rear) Spare tire carrier reinforcement. Rear diff cross-member. An AIR pump (I think). Exhaust manifold. AC plenum box. Vacuum reservoir can. Parking brake cable. Fertilizer spreader.
In the center below the pins is a 65-70 choke spring, rod and cover (Q-Jet?). To the right of the choke is a wheel weight and to the left is a headlight dimmer switch. Directly below the choke is a set of points, and to the left of that are 3 alternator terminal boots. Below the wheel weight is a vacuum hose "T" for the wiper/headlight vacuum hose system, and the ball is for the accelerator cable attachment on the carb. I can't comment on the exact application for the bolts shown.
You're good!
I swear to G-D!
As far as value goes...That smog pump is worth the whole stack!
The manifold heat riser, if it works, is a nice piece. Turbo 350 tranny as well!
There is a corvette only junkyard about 2 miles from here...a great way to spend some hours.
**** rating = 7.5! lol
I call dibs on the Air Pump. Screw it, I will take the whole pallet.
More than you know mike!
I've had my 69 Corvette since 1978.
3 dog's gone.
Multiple wimmins gone!
Houses gone!
Dad gone!
Jobs....psh!
States I lived in...(the Corvette has some 10,000 miles on it VIA TRAILER!)
Countries as well......
Yet, the Corvette shines on...
Admittedly....as I walk thru the garage EVERY time...I give that fender peak a little caress...
ok! I'll stop now! LOL
3 dog's gone.
Houses gone!
Dad gone!
Jobs....psh!
When I took off the rocker panel, this weather stripping fell out. Where did it come from?
I had a Mustang back in the day then I got a Camaro I remember opening the distributor door to set the points while the car was running my first time, I thought that was the coolest thing since sliced bread.
