Fuel sending unit question for Wilcox
Old 02-24-2017, 10:46 PM
BEJ
Support Corvetteforum!
BEJ's Avatar
Default Fuel sending unit question for Wilcox
So, I have a 75, with a fuel gauge pegged past full. I know that I have less that 5 gallons in the tank (bladder has been removed). In reading your write up on diagnosing fuel gauge issues, it seems that my issue may lie in the sending unit itself. My question is, when checking the post on the sending unit that the sending wire connects to for ohms, do I touch both leads from my multimeter to the post? The instruction manual for my meter says to put one lead on each side of the circuit, but how does that work with that tiny little post? I appreciate any advice that you can give.
Thanks,
Bryan
Old 02-25-2017, 04:01 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
remove the wire from the post and ground the wire, your gauge should go to empty. If it doesnt go to empty you have a problem with the signal coming from the gauge. If it does go to empty check the ground connection from the sender to the frame, if it is good, you have a bad sender.
Concerning your multi meter test above one wire goes to the post and the other wire to a good ground.
Old 02-26-2017, 08:19 AM
BEJ
BEJ's Avatar
Thanks Mel. After your reply, I went back and re-read the Wilcox paper on this and it all made sense. Seems that the sending unit was good and that the issue was just a bad connection of the wire to the sending unit post. Problem solved and gauge working as it should. Thanks for the help.
Bryan
Old 02-28-2017, 08:47 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Bryan
Good deal... I'm glad you figured it out.. but just a heads up for you and others...
I search for threads with Willcox, not Wilcox... So I missed this post. There are two L's in Willcox...
Ernie
Old 02-28-2017, 08:56 PM
BEJ
BEJ's Avatar
Ernie
Fair enough, darn extra L. Thanks for setting me straight. More importantly though, thanks for the Technical write up. Once Mel set my thinking right, I went back and re-read it and it all made sense. That paper really helped.
Bryan
To Fuel sending unit question for Wilcox
Quick Reply: Fuel sending unit question for Wilcox
