Body Lift Success!!
Body Lift Success!!
Hey guys, just an update. Removed the body earlier with no problems!! Birdcage held. Cheers
I took several pics of the frame, I'd appreciate it if you all let me know what you think of its condition.
Thanks,
-Matt
Thanks,
-Matt
Received 2,878 Likes
Hi 72,
It looks like you did a good job doing the lift!
The frame looks good in the photos. You'll know better when you start cleaning it up, but it's certainly appears solid.
Interesting repair on the fuel line.
Have you remembered to note the number of shims at each body mount location?
Big fun ahead!!
Regards,
Alan
I'd be interested in know if there's anything unusual about the pinion snubber nut. Either it's finish or configuration??
Big fun ahead!!
Regards,
Alan
Nice job. There's lots of work and time ahead. It looks like you have a great foundation for your restoration.
Frame looks good. I need to do this on my 71 this summer, hopefully. I have not touched it in years. I am afraid of what may be done to the frame. It sat for many years. I will have to remember to count the shims never thought about that. Better get a note book ready I guess.
Dementer sole survivor
Received 6,257 Likes
2016 C3 of Year Finalist
someday for me....... maybe 5 years down the line
The frame looks pretty good. If the birdcage is no worse, I think you're in good shape. Congrats!
Nice catch on the fuel line repair. Even without that, I'd be tempted to replace the fuel and return lines in any case. They don't look terrible but this will be the easiest time to replace them.
Hi 72,
Big fun ahead!!
Regards,
Alan
Big fun ahead!!
Regards,
Alan
Hi CA-L,
Yes I agree, there's not going to be a better/easier time to replace all the lines than now.
I just replaced all the stainless brake lines and the stainless vapor line on the left frame rail I had originally installed with Bundy steel.
It's not an easy thing to do with the body in place.
Regards,
Alan
Regards,
Alan
I was curious about the ties too at the diff crossmember. They didn't appear to be doing anything, but were bolted to the floor pan around the seat..? Also I accidentally cut the parking brake cable when removing the exhaust I planned on replacing it anyway so I guess it doesn't matter. & yeah I agree I'll definitely be replacing all fuel & brake lines while the frame is off!! Thanks everyone for the feedback. I thought the frame looked pretty good, but just wanted some more opinions. Doesn't appear to really even have much surface rust.
The rocker channels of the birdcage. Once you remove the rocker moldings/side pipes (if equipped) that cover it up you can easily distinguish the bottom lip of the birdcage from the frame. You can buy the same lift straps I did from any of the corvette parts suppliers that are specifically made for this lift. They have hooks on the bottom of them that fit nicely around the lip of the birdcage.
Hi 72,
Big fun ahead!!
Regards,
Alan
Big fun ahead!!
Regards,
Alan
Hi 72,
Big fun ahead!!
Regards,
Alan
Big fun ahead!!
Regards,
Alan
