4 bolt main 2 bolt main
Senior Member since 1492
It refers to the number of bolts on the caps which hold the crank. Here are pictures of a 4 bolts and obviouls a 2 bolt only has 2 bolts per cap.
The # of bolts that hold the crank bearing caps to the block. 4 bolts are desireable for very high horsepower engines. Some two bolt blocks have the place for four bolt caps- thay are just not drilled and tapped.Some people drill two bolts into four bolts (at an angle)-but withought the meat in that area of the engine you can actualy weakin the block. two bolt mains will hold up to alot of hp- more than most streetable rods can turn out.
thanks jimvette...I'm still new to this and the more I think I know the less I actually do. This has been on my mind since I discovered my engine is a 2 bolt. Obviously not the original motor.
What's the difference?
you'll see 5 (one at the front, one at the rear, and one between each set of cylinders) 'main-bearing caps', which clamp the crankshaft 'up-wards', into the block.
Older 'passenger' cars had 2-bolt-blocks and caps (one on each side of the cap/crank), while later 'performance' blocks had 4-bolt (TWO on each side of the cap/crank) blocks and caps.....
" Thanks for calling, next caller, please.....
"Grumpy", from Malvern, Pa., you're on..... "
Originally Posted by jimvette74
could be original many came with two bolt check the block casting #.
Originally Posted by Carl Granquist
On my L-48, where will I find this number? I've had folks tell me both ("probably a 4-bolt main" & "likely a 2-bolt main") and I'd like to check for myself to know for sure. Thanks.
Sometimes though, the casting number may not tell you for certain whether it's a 2 or 4 bolt.
My number listed above is posted as being a 2 or 4 bolt. Go look HERE when you get the number.
I was pleasantly surprised when what everyone told me was a 2 bolt turned out to be a 4 bolt!
Rick B.
My vin# shows mine to be a L 48..so it is supposed to be a 2 bolt main. It's a 78. Thanks for all the helpful answers, tomorrow if its not too cold down in the garage I'll see if I can check the numbers on the block.
Originally Posted by Jughead
Casting number is on the drivers side, back of the block, right where the block & tranny meet. Shine a flash light down there & if it's not too cruddy tou should be able to read a number like this--->14015445
My 1979 C3 Corvette VIN translates to An L48, but when I took the oil pan off to paint, I see my block is a 4 bolt main, it is all original, engine, transmission-Borg Warner Super T 10,is this possible?
Up until the Gen 5 came out in '90, there was no way to tell from a casting number on a big block whether it had 2 or 4 bolt mains with one exception - one '89 - '90 casting is all 4-bolt and it's a Mark IV block.
SBC 400's are a bit different - almost all of the "511" castings are 4-bolt, cast in the first two years of 400 production. 509 and 817 castings are 2-bolt, at least 90% are, I won't say all until I've seen 'em all.
SBC 350 is a crap shoot just like big blocks - all casting numbers after about '70 can either be 2 or 4 bolt mains.
Big blocks have the same number of bolts on all 5 caps, small block 4-bolt blocks only have 4 bolts on the middle 3 caps, front and back are 2-bolt.
Best way to tell easily is to drain the oil and use a borescope through the drain hole. Don't buy the cheapie from Harbor Freight, the camera/light on the end are too big for drain plug and spark plug holes but the more expensive one has a much smaller end and works for both.
If you are not the original owner check the engine stamp pad to see if it has your partial vin # and also the suffix should be ZAA or ZAF.
If you see a 4 bolt then it is what it is.
