Help installing seat cushions on 79-82 seats
I am stuggling to get the back seat cushions installed into the seat enclosure/frame. These are the pre-covered cushions. The bottom's clipped in fine but I cannot seem to get the backs to clip in. Any advise?
Alwyn678 (11-18-2015)
kp68elky (07-29-2020)
I recently did my '78 pace car which is the same seat pan. First,cut away any excess foam from around the attach wires in the seat foam. IMPORTANT! Make sure the hog rings are no where near the seat wires where they could interfere with installation. Next,Use 2 long screw drivers. Hook the wire and pull it away from the foam as far as possible while using the other to guide it under the hook. BTW, pry the hooks in the plastic pans open a tad...it helps! Do the top first, then bottom on same side. Turn it around, carefully applying pressure on your newly hooked seat back so it doesn't pop back out. Then use the same technique on the remaining side. I called Knoch to get those tips and believe me....be prepared to sweat a bunch too.
Good luck,
Mike
Good luck,
Mike
Thanks for all your input. I am going to have another try at installing using the screw driver trick and removing some more excess foam. If no luck then I will go for the velcro approach.
Buffed78... where did you attached the velcro...sides of the cushons or bottom
I dunno...I think its worth the sweat if you can possibly re-hook the wires. If velcro does work, than you must have used quite a bit and I don;t think it would stand up very well to heat an time.
Mike
Mike
Thanks for your posts. I was very close to giving up and going the velcro solution. But, after working with it for a while I was able to get them in using the two screw driver method along with your other suggestions...eg cutting away some of the foam. What a bear and bad design this is. Oh well...done now. Thanks again to the forum
